  • Just got home from vacation, cam still hasn't shown up
    2002 Z28 Camaro A4
    • Cam is here!!!! Wooooooooo!!
      Im swinging by the machine shop tomorrow on my lunch break to drop it off and get an update.
      Can someone post the pic for me please
      http://m571.photobucket.com/linkcode...PGB76S5t%2FjpF
      2002 Z28 Camaro A4
      • What cam did you end up going with?
        • Looking good Micheal!
            LE's. 226/232
            Thanks for posting the pic Kyle, it won't let me on my phone.
            2002 Z28 Camaro A4
            • Just dropped the cam off. He said it would be a few weeks before it's done. I guess he is slammed and he said he has a few in front of me. Basically that puts me to a hault. I think I'm going to get the trans to the trans guy.
              I also need to order new rod bolts. Should I get new main bolts?
              2002 Z28 Camaro A4
              • Got some more things powdercoated.
                Also, I talked to my trans guy. He said 200-300 for labor and what ever extra for parts. What all should I look into getting for upgraded internals for my 700r4?
                2002 Z28 Camaro A4
                • Y'all don't love me anymore :/ suggestions where I should buy main and rod bolts?
                  Rods
                  TSP- http://www.texas-speed.com/p-2553-ar...etal-rods.aspx
                  Summit- http://m.summitracing.com/parts/ARP-134-6005
                  Mains- http://www.texas-speed.com/p-2550-ar...e-journal.aspx
                  What's with the "large journal" on the mains? Is that what I want?
                  2002 Z28 Camaro A4
                  • PAYPAL ORDER RECEIVED
                    Win....
                    2002 Z28 Camaro A4
                    • Finally got the rod and main bolts in. That was a joke, there is no reason it should take 2 weeks to send me a few bolts... I won't be ordering from them again.
                      Hopefully I will get out of work early tomorrow so I can drop them off and check on the motor. I wonder what his excuse will be this time...
                      Couple of questions on my mind...
                      1) will I really benifit from a tubular k member or should I spend the $400 elsewhere?
                      2) suggestions on a new oil pan?
                      3) is there anything I can recoat headers that actually works and won't burn off within 10mins of run time?
                      4) what is needed to get the 11" ZR1 wheels to fit in the rear? BFH?
                      5) I was just reading in the latest issue of gm high tech performance that the waterpump cuppler (the one I posted a pic of way back during dissassembly, all rusted out) that they are pretty hard to come by. Suggestions? Mines toast...
                      Thanks homies
                      2002 Z28 Camaro A4
                      • What's the main goals for the car? Tubular k member isn't really a must have. Is spend it elsewhere now unless u have the extra cash. Yes a bfh for the zr1s.
                        • Originally posted by MunsterZ28 View Post
                          Track/weekend car
                          2002 Z28 Camaro A4
                            Track/weekend car
                            I would go with a tubular kmember.
                            But then again I start to lean more towards the track side of things as time goes on.
                            My car has been on the road for a month now and I have only driven it 300 miles. A lot of that time has been spent at WOT
                            • I have 10.5" wheels on the back with a 53mm offset and I didn't have to do anything to get them to fit. If they are a 56mm offset you might need a bfh.
                              • My local Chevy dealer had me a waterpump coupler in 2 days
                                2015 Silverado
