  • Originally posted by ryanwarby01 View Post
    Budget and LT1 don't go great together, but I get what you are saying. I started with a Delco opti then went with a Dynaspark when I should have just went with the LTCC to begin with and spent about the same amount of money. Also, I kept a Chandler for a spare and had to use it a couple of times and it worked great.
    Yeah any motor in general can't really be a budget build if you want everything done right although there are things I can cut back on. For instance I also think I'm going to use stock trans until she goes, which I don't expect to be too long.
    2002 Z28 Camaro A4
    1993 Z28 Camaro M6- SOLD
    1999 Z28 Camaro M6- SOLD
    2008 Ford Fusion SE - DD
      At this point I would look into the LTCC coil conversion to ditch the opti. For the money you would spend on a good opti your half way to the conversion kit, plus much better tuning abilities
      This would be well spent money since you have a 93. You can tune the engine far better than burning prom's and guessing.
        I definatly don't plan on ruling it out just yet. I just rather make it a future mod. As long as I find a good tuner it shouldn't be too much of an issue.
        2002 Z28 Camaro A4
        • Any updates?
            Any updates?
            Talked to him today, should have it middle of next week... So he says.
            I have been slammed at work and just purchased a new gun
            I'm going to stop by Tuesday or Wednesday. I'm hoping it will be no more than $500
            2002 Z28 Camaro A4
            • Maybe you should not have bought gun, you might shoot yourself when you get price. LOL
                Haha, do you really think it will be over $500? The cam, rings and pistons, rod and main bolts are all paid for. The only "parts" he supplied is cam, main and rod bearings, soft plugs and a rear main seal.
                As for labor he bored .030 over, cleaned block, assembled shortblock and polished the crank.
                2002 Z28 Camaro A4
                  I had similar work done on my block a couple years ago, it cost me $1000 and that was a damn good price.
                  • What gun did you buy?
                      Xdm 9 with the stainless slide
                      2002 Z28 Camaro A4
                        I just looked at that gun with the 3.8" barrel, but I ended up buying a Springfield 1911. Those XDMs are awesome.
                        • I love my XD45. I just bought a FNP-45.
                          Originally posted by Yoshi94
                          • He needs my main caps and rear main seal housing?
                            I know what the caps are but what is the rear main seal housing? I doubt he got a new seal. Pics? Thanks
                            2002 Z28 Camaro A4
                            • Nevermind. Looked through my parts and found it.
                              He played dumb with me today asking if he was assembling the shortblock. No idiot I gave you arp rod and main bolts as a donation!
                              I'm dropping by the main caps and rear main seal housing on my lunch break tomorrow.
                              2002 Z28 Camaro A4
                              • Update on block
                                Dropped off rear ms housing and main caps. He ordered a gasket kit and said all said and done just shy of $800 buttttt since he knows me and it took so long $600
                                Good enough for me! He said plan on picking it up Wednesday.
                                Also he said he had to resize the rods, that arp said so. What's that about?
                                Woooooooottttt I'm geeked.
                                2002 Z28 Camaro A4
