  • What is the size of the shaft for the oil pump? My buddy owns a local parts store and I'm tring to help him out.
    2002 Z28 Camaro A4
    1993 Z28 Camaro M6- SOLD
    1999 Z28 Camaro M6- SOLD
    2008 Ford Fusion SE - DD
    • Okay so I got the windage tray main bolt sitiuation figured out. I guess arp didn't start making the windage tray bolts until recently. I must have gotten an old box. Guys since then have been running stock bolts on the 3 windage tray ones. So my buddy works at the local chevy dealer get me 3 new stockers.
      I just ordered (don't hate) a "how to rebuild LT1/LT4 engines" off amazon. I'd like to have another reference.
      I have read to torque the main bolts to 77ft lbs and 80ft lbs. Can anyone verify this? I tried contacting the shop with no luck. I'm doing the rest on my own. I am not going to take my block back there to sit around for 3 months!
      Should I use any type of locktite?
      Does anyone have a pic of the driveshaft for the waterpump?
      I had a dream lastnight that I started this up. I'm anxious now!
      Thanks all!
      2002 Z28 Camaro A4
      • When you get the book from amazon there should be a picture. the assemble is a gear that meshes to cam shaft inside the block then has a bearing and a plate to hold it and a splined shaft to mate with water pump drive coupler. This assemble goes above large cam drive sprocket and partially behind it. You can probably loosen the 3 bolts on cam holding large sprocket enough to get this inplace (note timing marks on small and large chain sprockets for cam)
        • Well I picked up a used EWP for real cheap today.
          As many are against used valvetrain, I'm going to be that guy. After this car is all said and done I'm still looking at ~$3,000.
          Can you post up some top brands of valve springs, pushrods, rr's that I should get? I think im going to get brand new lifters tho.
          Got a guy that has a set of crane gold 1.6 rr's fir $115 shipped. Should I get them?
          Also, is my lift specs in my cam based on 1.6 or 1.7 roller rockers?
          2002 Z28 Camaro A4
          • I used red Loctite on my main studs. I just put Isky Gold Endurance springs on my heads. They aren't as well of a known name as Comp, but they are still quality parts. Buy LS7 lifters as that will be the most cost effective. I run the Crane Gold 1.6 re's. You would have to check your cam card to see what rockers they base the specs off of. Most use 1.5.
            2015 Silverado
            • I just looked at the cam card. It's based off 1.6 rr's.
              Is that an ok deal on them cranes?
              Anyone used these? http://www.jegs.com/i/Lunati/638/73943/10002/-1
              Now that I got an EWP, what holes on my timing cover do I have to weld up?
              2002 Z28 Camaro A4
              • Whats the car look like at this point? Is it put back together just waiting for a motor?
                  The k member is in it so I can roll it around.
                  Both bumpers are off, I don't want to start the body work until she can move under her own power. Then a buddy and I are going to knock out the bodywork one week then get it painted at work on a weekend.
                  Interior wise I just need a headliner and a dash pad. Other than that it's all back together.
                  2002 Z28 Camaro A4
                    That is a good deal on the Cranes. I paid $300 new I believe for mine a couple years back.
                    Those springs look cheap dude, they're only singles. Look into those Iskys I told you about. I think mine were $170 with spring, retainers and keepers. I don't have stock heads though so I don't know what the difference would be.
                    You could weld the top hole I suppose. The people who owned my Firebird before me installed an electric water pump and they just let the water pump drive stick out of the hole.
                    2015 Silverado
                    • Here is some info on the cranes, they have 20k miles on them. I just don't want to get screwed.
                      http://ls1tech.com/forums/parts-want...l#post15621477
                      2002 Z28 Camaro A4
                      • I recommend PAC1218s beehives. Thats what i have and ive had no issues in 10k miles. PAC used to be the supplier for Comp... in years past 1218s were what comp sold as 918s before comp got cheap.
                        • Could step up to 1518s too, sdpc has them for $188. Either way, cant go wrong with PAC. A lot of people run the 1218 and 1518 springs. I run the 1518s myself, about 20k on them now IIRC.
                          • Thanks guys! How about the rockers I posted a link to?
                            2002 Z28 Camaro A4
                            • Got the windage tray main bolts in. Torqued to 80 ft lbs.
                              I can't find my windage tray nuts.
                              2002 Z28 Camaro A4
                              • Rockers look like a good buy if they fit your application
                                2015 Silverado
