  • you really don't need a lot of rpm I doubt a stock 5.3 will make power above 6K with a turbo, that being said even though you don't have lockup you still have 4th gear so 3.50 would be fine for cruising around IMO.
    • What do you think the rpms will be at on frwy doing 75-80??
      - - 5.3/4L80e/T7875 - -
      - Huron Speed Turbo Kit -
      1998 Formula
      • you really wont know until you get them in there.. but seriously put 3.50's in it and dont think twice just trust me.
        • http://www.f-body.org/gears/
          3.50 gearset
          26" tire
          4l80E
          75-80 approximately 25-2700rpms just depends on your converter slippage, but factoring in 5% is usually a good estimate.
          • All depends on what RPM you trap the 1/4 in.
            • Originally posted by Formula Z View Post
              What gear ratio for a 9" would be ideal? Thinking a non lockup converter so was thinking 3.0 or 3.10s. Which brand without breaking the bank? Thanks
              Are you going to go over 800rwhp, if not why a 9 inch?
              You will loose less power to the wheel with a 12 bolt.
              • 12 bolt f-body axles are junk...
                • Got a great deal on a moser 9". I dont think my stock 10 bolt w 3.73s is up to the task
                  25-2700 rpms still seem high with 3.50s. I guess if you guys think 3.50s will be better stoplight to stoplight, im good. If it will help build the boost and still be hghwy friendly im all for it
                  1998 Formula
                  • There's a couple 12 bolt f body's putting way over 600 up to the wheels here in flint. No issues. I mean there not not bullit proof. But Im sure you have reason for your opinion.
                    If you got a deal on a 9inch then I completely understand, gives you room to grow.
                      If it helps I was running a 3.08 for the street and would switch 3rds to a 3.50 for the track. For street or highway I feel a 3.50 is alittle high myself. But for splitting often street/track. Iv seen a lot of people run 3.50 with plenty of luck.
                      • Originally posted by masterfab View Post
                        and i would also bet that you had a 3 spd trans not a 4 like he has..
                        mike 3.50's will be great for your car. i have them in mine and am running a th400 and its very streetable and cruises down the highway great
                        • Now I need a locker and gears
                          1998 Formula
                            Nope a 4l60e. 2700rpm is high rpm for a 4 speed v8 car. my raised mine for milage. most v8's carry enough torqe to cruise highway speeds and maintain around 2000rpm.
                            Not saying 3.50 is a bad gear. But there are more streetable gears.
                              not disagreeing with the fact that there is more streetable. if your only going for fuel mileage.. but lets be honest.. we didnt buy these cars to get great mileage. i run a 3.50 in mine and it is extremely streetable and i have a 3 spd instead of a 4. which means mike will be every bit just fine with the same gear. sure you could go with a 3.00 to get better mileage but then its not going to help when you go to the track or wanna have some fun. its just like how guys run a 3.73 when they have a 10 bolt in the car with a 4l60. it works just fine.. just like a 3.50 works great.
                              btw mike.. stay away from the 3.25 gear sets if you think about not going the 3.50 route.. i had three of them and bc they are not a very common gear set they are generally very loud..
                              • What rpm are you hitting peak up Sean. This is my main concern. unless he also has a unlimited budget to replace rods and pistols.
