  • Sent from my SPH-L720T using Tapatalk
    • Tune scheduled for July 21st
      • Awesome!
        • Took car to get the exhaust finished up. Basically connect downpipe to catback. What a huge difference this made in sound, and i dont think i like it lol. Too quiet. Tune is scheduled for the 21st with tj @ bakers. Still have a couple issues to wrap up before then. One my speedo kinda follows the rpm to a point and settles somewhere around a 100mph. i think thats a simple fix. fuel gauge still reads full ( thought that was fixed when the 4l80e segment swap was done, but no biggie, yet). Now car wants to die when put in park or neutral but runs great when in any drive gear. Unplugged iac and it idles but at about 1200-1400 rpm. I need to figure this out. Less then 2 weeks and i still need to get the dual walbros and racetronix hobbs switch and hotwire kit installed. Im a little nervous about this. I cant wait to get into the boost a little
          • Stock shifter? Could be the tune . The prndl on the shifter tells the Pcm P/n for idle
            • Car is finally done and with TJ at Bakers Engineering. Dyno tune today or tomorrow. Not liking the temp outside for this but? How much boost can you run on 93 octane? Running 12# Springs and hoping for 600-650 whp but tj says 12 is a little high for 93
              • I need a 99-02 unmolested harness asap
                • So something in the harness is still screwed up. Getting feedback through the obd port causing issues in whatever laptop is plugged into it, car wont idle in park or neutral but runs flawless in any forward gear or reverse. So it cant be tuned. So its all coming back out. Its so disappointing but i can redo some things i rushed on. Hoping 2017 will be better
