  • Originally posted by Formula Z View Post
    Pm'd you jonny
    • Looks like a badass build you have going. Pretty much the setup I am wanting to run. I cant wait to order my Huron Speed kit in the next couple months.
      2005 Chevy 2500HD, Duramax, DD/tow vehicle, 20x12's, DSP5 w/Kory Willis tunes, head studs, EGR delete, LBZ MP, 4" MBRP
      99 T/A, A4, Black, SLP Flo-pac, LMII, LS6 intake, PS LT's, TSP ORY, 42# injectors, stock 243's, comp cam 230/232 612/595, UMI rear suspension, Yank SS3600, Built trans, 3.42's, other small stuff.
      11.72 at 116mph, 1.61 60ft, N/A
      11.41 at 124mph, 1.72 60ft, a little giggle gas in 2nd/3rd and no traction
      New setup in the works!!!
      • Ok guys what do I use for the head stud moly lube? Installing mine this weekend now that I got everything for assembly. I dont have arps but did get the ebay studs that everyone is using. Torque sequence?
        • I always use ARP ultra torque lube
          2015 Silverado
          • Well got the cam in, ls7 lifters in, comp cam trunion upgrade done, and the oilpan drilled and tapped and the drain installed. Got the stock valvesprings off but had to order the comp cam ls valvespring tool because the one I had wouldnt even attempt to compress the btr dual valvesprings. So more progress next weekend
              You could have borrowed my Crane Cam ls spring compressor
              • Thanks Mike, I actually had 3 offers to borrow tools but figured as much as im getting into these engines, it would be a good addition to the toolbox.
                • Always looking for an excuse to buy tools lol
                  • Yeah, but that would have been $100 towards your turbo
                    On the plus side, you can do some side jobs with it and make your money back
                    • True
                      • Originally posted by hoogiesngrinderz View Post
                        this is great knowledge to have.
                        now i know where to go
                        • lol now that you said that you will never have it. Everyone else will. I might get rid of mine and get the LSM tool since the crane wont work on all heads
                          • If you West side guys need an LSx tool (or any other tool) just ask. Crank pulley puller, power steering pulley remover/install, 320 grit ball Flex-Hone, spring compressor, etc. Don't have a pushrod length tool yet, but that can be done mathematically 20 ton press in the corner!
                            • can i borrow a 60mm impact socket?
                              • Haha, you've asked me that before.
                                I don't think I have a socket of any sort that big (maybe 54mm) but I don't work on heavy equipment
