  • Thanks but I think I have a tial wg lined up, just gotta fork over the money lol. Just not wanting to spend any until the building is done
    • Pole barn finally finished excluding electricity. Will get to that next. Firebird finally given some room. Hoping to get working on it again soon. Only need a 4L80e stall and injectors. Oh and some time to do work. Currently doing 60 hr weeks. Anyone need a job, Weller truck is hiring
      • Looks good Mike!
        2000 Formula
        fixed slow junk
        • Barn looks great. Cant wait to see some numbers from your car.
          2005 Chevy 2500HD, Duramax, DD/tow vehicle, 20x12's, DSP5 w/Kory Willis tunes, head studs, EGR delete, LBZ MP, 4" MBRP
          99 T/A, A4, Black, SLP Flo-pac, LMII, LS6 intake, PS LT's, TSP ORY, 42# injectors, stock 243's, comp cam 230/232 612/595, UMI rear suspension, Yank SS3600, Built trans, 3.42's, other small stuff.
          11.72 at 116mph, 1.61 60ft, N/A
          11.41 at 124mph, 1.72 60ft, a little giggle gas in 2nd/3rd and no traction
          New setup in the works!!!
          • Wow its been a long time since ive posted on my build. Its still going lol. Having zero insulation in a completely metal building and this winter we've had, i dont spend much time out there. i have rebuilt the 4l80e and even had it dyno'd at work. Picked up a 3400 stall that came out of another similar turbo car. Couple weekends and the harness will be repinned then i can use the 99 pcm i picked up from jonny. I still have to modify and install my dual walbros and still need a wastegate, and today i figured out that im going to need a tunnel mount torque arm. Damn it i thought the expensive stuff was done. Should be able to start doing final installation within the next couple weeks as long as we can break the freezing temperatures.
            • Glad to hear. About time an update
              Get a few heaters in there and get to work!!!
              2002 Z28 Camaro A4
              1993 Z28 Camaro M6- SOLD
              1999 Z28 Camaro M6- SOLD
              2008 Ford Fusion SE - DD
              • I have a big torpedo heater but it has to be real close just to stay warm but the noise drives me insane lol
                • Mike, someone has to make a cross member that works with your torque arm. Check with MWC, BMR, and others. Sorry the one I sold you is for a short torque arm.
                  The cross member will be cheaper than a torque arm setup.
                  2000 Formula
                  fixed slow junk
                  • It's cool. I'll figure something out. $400 for a tunnel mount is not in the budget at the moment if I wanna drive my car this year. I see jegs sells a cheap alternative . Idk I'll get something. Thx
                    • Glad to hear you're making progress. let me know once its done so I can check it out.
                      CAMMED M6 (375RWHP/371RWTQ)
                      • Definitely. It'll be done soon. Not soon enough but I'll be enjoying it this spring. Hope to make the meet and greet and ignace.
                        • sigpic
                          • Realizing I'm still in need of a few things. I need a feed line with restrictor, an alternator relocation kit, air filter for turbo, and turbo blanket. Anyone have anything laying around?
                            • You might want to consider running a 90* fitting into your oil pan for the drain in an effort to keep it short as possible and eliminate potential uphill runs. Looks good otherwise
                              • Yeah I had thought that as well. It's not hooked to turbo yet just sitting there. Hose is too long
