Originally posted by Gregs_gsxr
View Post
i just took off the heads off our 6.0, 2 of the bolts, longer ones if I remember right, have corrosion right in the middle of them...engine does run doesnt burn or leak anything.Originally posted by c0ncEpT View PostJust like every other LS based motor LQ4's do not have head bolts that enter the cooling passages. You must be thinking of something else.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Originally posted by 1BADAIR View Postshouldnt be. were the heads off before? you mean the 2 shorter bolts.
early blocks have 2 shorter ones. 2004-later are all the same
Now you say that I dont remember it was last week, and the '52 chevy is at the steel shop in Redford...not something I can just run to real quick lol heads where not pulled off before. I wish I would have took pics of them cause it was odd to me too when we seen them
that 6.0 is a 2003 that its the '52
the other 6.0 is 2002 or 2004 thats in the LeMans'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Grammar Nazi
- January 10th, 2006
- 6647
- Jonny
- under par
- Huron Speed
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
https://www.google.com/search?q=head...ient=firefox-a
Tons of stuff about head studs leaking on LT1s.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
If you use the correct sealant/use it properly there shouldn't be an issue. I've made this mistake before.Originally posted by Fox Slaughter View Posthttps://www.google.com/search?q=head...ient=firefox-a
Tons of stuff about head studs leaking on LT1s.2015 Silverado
look what showed up. already got the fmic and bov. this must be the rest. thought i ordered some swag
535598_10151356289417983_337405962_n.jpgsigpic
