Originally posted by Formula Z
View Post
Grammar Nazi
- January 10th, 2006
- 6647
- Jonny
- under par
- Huron Speed
I can get you one for a few bucks cheaper! Send me an e-mail to huronspeedproducts@gmail.com and I will get you over the custom spec sheet and we can get it going!sigpic
Re: hp/tq/ and 1/4 with a 76mm/78mm turbo
Just had a friend and the guy who purchased my 4L60e stop by with a surprise. seems he had laying around a dual fuel pump out of a 99 camaro. Said I could have it. much to my surprise they are walbros. he said they worked when pulled. how do i go about testing these? anyone have a part # for the walbro that i can double check? any thoughts, ideas, or concerns? also just found out they are the gss307 model which isnt the ones everyone wants even though it is still twin 255s
Sent from my SPH-D710 using Tapatalk 2Last edited by Formula Z; January 30th, 2013, 08:26 PM.sigpic
The gss307 is a pump that a lot of the buick guys used before the gss340 came out.
The gss340 is more suited to flow at high pressures.
http://www.racetronix.com/307vs340.html
http://www.gnttype.org/techarea/fuel...albroflow.html
That being said - I wouldn't be surprised if they'd work just fine for you.
I assume your going to stick with return less fuel system? At 60psi you shouldn't notice a difference in flow.2000 Formula
fixed slow junk
Returnless? dont think ive gotten that far in my research lol. im going to keep it as simple as possible if it will suit my needs.
Sent from my SPH-D710 using Tapatalk 2sigpic
Yes - your factory feed line will limit you before the twin pumps will. Those are good pumps, not as good as the newer pumps - but they'll get the job done.Originally posted by Formula Z View PostBut it will work fine like it is?? Thanks guys
Larry - yea yea......it's close enough - fuel doesn't return from the rail
2000 Formula
fixed slow junk
Would it hurt to hook up a 12v source and make sure they work? what would be the proper way to test them
Just got a PM that my huron speed turbo kit is almost ready to ship. now if this weather will warm up so i can get started.
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
I've heard people have problems with getting studs to seal.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
