Charlyne 95 Z28 M6
    Just got my o2 bungs welded in so now I need to wait for it to dry up so I can put in my FAST Dual Wideband o2.
    pics or it didnt happen
      Yes let me crawl outside in the rain and lay under my car with my camera in the rain and then get soaked in the rain to take pictures that were taken in the rain.
      Originally posted by Yoshi94
        post em up then.
        • Alright got my exhaust finished now, have to order cut outs. It hangs low haha. 3" with X pipe Pacesetter Ceramic Long Tubes, Cut outs, Delta Flow 40s at the Axle. Ill get some pics up in a few mins. Plus pictures of my Wideband o2s.
          • Vids or it didn't happen
            • Here is a few pictures. Video for some reason got quite when the exhaust came on haha. Cutouts are Closed in that video.
              • I started to install my rear suspension parts but I could only get one side of the panhard bar off and couldnt even get the bolt out. I have a 1/2" impact gun that supposably does 625ft lbs and it wouldnt even move the driver side bolt, passenger I took off with just a socket wrench. I guess I'll have to start soaking them in PB Blaster.
                • looks great man. Sounds good too.
                  How loud is it when cruising around?
                  • Super quiet with the cutouts closed. My neighbors lawn motor is louder then it at full throttle.
                    • Joels car with the exact same setup set off my car alarm repeatedly.
                      • Originally posted by my95z28 View Post
                        the cam and cutouts must make a difference lol. My car wakes the neighbors up if i dont get a good run at the driveway late at night
                        • my panhard bolts are the EXACT same way.. i am just gonna torch mine out lol.. they are completely rusted in there. exhaust sounds good. i had a pretty similar set up last summer.. you should like it.
                          97 TA AI 355
                          2012 Jeep Patriot
                          • sawzall ftw. just make sure you replace with grade 8 bolts!
                            • I had to beat mine out, lots of heat and a mini-sledge.
                              • I tried using a 3lb baby sledge didn't work haha.
