I pulled the injectors off the rail. Question is what should I do now? I plan on sending the intake manifold to AI and having a street/strip job done to it and putting on a 58mm throttle body, having the heads rebuilt possibly mild port job. Should I just send the stockers out to be cleaned or go bigger?
Charlyne 95 Z28 M6
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
dont waste your money on the intake work unless you plan on doing something with the heads.. the stock intake works well up to 400 whp. And i guess i dont know what your goals are for the car? AI makes the stock head flow really well(lots of stock ported heads in 10s) so i guess its all up to you and your budget. and goals.97 TA AI 355
2012 Jeep Patriot
Lurker
- March 13th, 2010
- 3476
- TJ
I already got an invoice from AI. I was gonna send the heads in and have them do the 200cc job and valve train. I don't have 5500 dollars to spend right now. I'm pretty sure I have a messed up valve on the passenger bank thats where the head rebuild comes from. Its 350 to have the intake ported, so its just a small set to having the entire top end done.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
gotcha, well i guess if you dont have the funds just do what you can to fix the heads and dont waste your money on the intake. i have ai heads with a stock intake and make good power. a guy on tech makes 450 whp with a un ported intake. so save your money for heads.97 TA AI 355
2012 Jeep Patriot
Lurker
- March 13th, 2010
- 3476
- TJ
Well I emailed AI and asked them if its worth to have the heads worked and run a stock valve train because I won't have the money to do both. The heads need a valve job. So debating on just doing a stock rebuild or let them work them and run stock valve train for now.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
If your going to pull the heads and have the valves done, I would put my money in a cam and roller lifters, new springs, while it is apart. the trottle body and intake can easily be done later when you have more funds, and at that time I would do injectors. either way you'll need a tune each time..
Call Steve SB Tuning our sponser he can set you up for tunes and he has a guy to do head work.
OBTW put away the big hammer for the rest of your build! LOLsigpic
Lurker
- March 13th, 2010
- 3476
- TJ
I am tuning myself. Tunercats and dual wideband. The problem is the valve job needs to be done. Then I wouldn't know what lifters and stuff to run. Cause I'd probably run it till next winter the hopefully do my AI build.
Next time it's a full size sledge hammer I'll break out.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
Scratch This Post.Last edited by Fox Slaughter; January 7th, 2012, 02:21 PM.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
UPDATE:
Well I got the intake manifold removed, rockers, push rods. Drained the coolant system. I can't get the banjo bolts on the back of the heads lose. The driver side I can't even get the wrench on it, passenger side I can but I can't get enough torque to move it, can't fit he pipe I have on the wrench under the cowl. Any ideas?
Also I am at a toss up. I'm thinking of doing a valvetrain and cam swap. The valvetrain will be easy once the heads are off, but the cam is another story. Should I drop the K member to do the cam swap? If so anyone wanna come over and help (as long as the snow stays like it is, gone)? I have engine stands and a engine puller (cherry picker). I've done it before on a Saturn but never a F-Body. So if anyone would like to help get you a case of beer for the help.
399490_2863415661029_1128857949_3063630_1535477182_n.jpg374878_2863835591527_1128857949_3063730_256364058_n.jpgOriginally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
Ai 226/234Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Nice, I was debating between that and LE's 226/232, LE was $115 cheaper and AI wasn't going to have any in stock for 3 weeks. Although this was about 3 months ago. So I went with LE'sOriginally posted by Fox Slaughter View PostAi 226/2342002 Z28 Camaro A4
1993 Z28 Camaro M6- SOLD
1999 Z28 Camaro M6- SOLD
2008 Ford Fusion SE - DD
Lurker
- March 13th, 2010
- 3476
- TJ
I'm planning on getting their matched valvetrain set. Plus I plan on sending my heads out to AI so I wanna try to stick with them.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
Welcome to a 4th gen Fbody haha.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
