Charlyne 95 Z28 M6
  • Ordered a miniature shift light. No more having to look down at the inaccurate dash tach or take my eyes off the road.
    Originally posted by Yoshi94
    • Shift light is now installed.
      • Shoulda put it in the vent
        • I can put it anywhere. Its just double sided tape holding it on.
          • UPDATE:
            Speed Density tune is pretty much where I want it. Maybe just a little bit more tweaking but overall pretty damn good.
            • Got a little bored.
              • Got a Porter Cable 7242XP.
                383552_3450437776215_1128857949_3324615_1872843731_a.jpg Spoiler Before
                528111_3450446216426_1128857949_3324622_2077881345_n.jpg Hood after, not perfect need more aggressive pads
                545253_3450439536259_1128857949_3324616_1236376061_n.jpg Spoiler After
                545822_3450441376305_1128857949_3324617_1435968255_n.jpg Spoiler After
                549899_3450443376355_1128857949_3324620_710433648_n.jpg Hood Before
                • Looks good dude! Those porter cables are awesome!
                  • Saw you pass by auto europe last night TJ - why didnt you stop in?
                    Nice work with the porter cable. You might not need more aggressive pads... Sometimes while better results are possible, its a situation where you are doing double or triple the work for 10% better results. Especially with black. You can usually save time by working really slowly with finer pads/polishes than polishing with a heavier cut and having to correct the swirls. The last time i went harsher than swirl remover on my car it was a multi day project.
                    I just got my buffer out for the first time in 11 months today. Still in progress, Pics to come.
                    • I will probably stop in tonight. I just did a couple laps yesterday and went home to eat.
                      • Pulled the spare tire and jack and weighed them and AC crap and AIR pump.
                        So far have pulled 58lbs out of the car.
                        • Did you get it weighed before the weight reduction?
                          2002 Z28 Camaro A4
                          1993 Z28 Camaro M6- SOLD
                          1999 Z28 Camaro M6- SOLD
                          2008 Ford Fusion SE - DD
                          • Sadly no. I am just guessing by using a bathroom scale and weighing the parts. There is a semi scale by where I work and when I drove the Camaro to work I forgot to weigh her.
                            • UPDATE:
                              Got some new rubber on the back end. Must better traction! Before I could just hit the throttle in first and they'd spin, now they will hold on longer till the RPMs get up.
                              Also wired my Wideband to the AC pressure switch so now I can log the AFR.
                              • Originally posted by Fox Slaughter View Post
                                Are using DataMaster or TunerPro to data log with? I wonder if it'd log with TunerPro just the same as DataMaster?
