Charlyne 95 Z28 M6
  • [Project] Charlyne 95 Z28 M6
    I am going to start my build thread it will probably sit idle for a while.
    Anyways...
    The Car: Charlyne
    1995 Z28 Camaro LT1 T56 6 Speed Transmission
    DSCN0056.jpgDSCN0055.JPGDSCN0050.jpgDSCN0004.jpgDSCN0006.jpgDSCN0053.jpgDSCN0005.jpgDSCN0054.jpgDSCN0003.JPGDSCN0052.jpg
    Purchase Mods:
    • K&N Cold Air Intake
    • Aluminum Driveshaft
    • DynaMax Cat Back (Removed from Car)
    • 275x45x17 Geforce Rear/Comp T/A Front
    Future Mods:
    Exhaust:
    • Custom 3in X pipe with cutouts and Flowmaster Delta Flow 40s (Finished pics on page 18 besides cutouts)
    Transmission:
    • Hurst Billet Plus Shifter (Installed)
    • UMI Short Stick (Installed)
    • Pistol Grip handle (Installed)
    • Tick Shift Extreme Viper Rebuild
    Rear End:
    • Strange S60
    • Richmond Pro 4.10 gears
    • Driveshaft shortened
    Engine:
    • AI 200cc Heads
    • AI upgraded valvetrain including 1.6 Rocker ratio
    • AI custom billet ground cam (Still working on specs)
    • AI Street/Strip Manifold Porting
    • AI 383 Forged Rotating Assembly
    • Electric Water Pump
    • AIR Removal
    • Pacesetter 1-3/4" Race Long Tubes (Installed)
    • EGR Delete (Installed)
    • A/C Delete
    • Throttle Body Bypass (Installed)
    Suspension:
    • BMR K Member
    • BMR Rear Control Arms
    • BMR Tubular Upper and Lower A Arms
    • BMR Torque Bar
    • Weld In subframe Connectors (Installed)
    • QA1 Shocks and Springs
    • BMR Panhard Bar (in basement)
    • BMR Lower Control Arms (in basement)
    • BMR LCA Relocation Brackets (in basement)
    Brakes:
    • Haven't decided yet. Probably C5 Corvette Brakes
    I am open to suggestions. Also about the Dana 60 since I know that is gonna draw some interest. Yes Ford 9in is a great rear end but I refuse to put a Ford product under my Chevy.
    This project is probably going to be close to a 5 year project.
    Originally posted by Yoshi94
    We have similar ideas for our cars.
    Seems odd that its your car and not Kyles. lol
      To me it scream, nightshade stock amber turns & get rid of the clears JMO
        Complete opposite opinion here, I love those clear corners. Niteshaded amber corners would just look dirty.
          If I remember right the S60 weighs a ton and is a huge powersuck, besides that it's really expensive. Which is why I'm going 8.8 eventually.
          Used to own a Firebird.
            if you don't want a ford product just go with the Moser M90 The S60 like vinnie said is heavier and robs more power than a 9" anyways.
              Yeah, the Dana 60 is a beefy mother****er.
              Suck it up and throw a 9" under there.
              It's not the end of the world.
                A s60 weighs like 25-50 more then the 10 bolt. It robs like 6% compared to a 9 that robs like 10%
                  But why not just build an 8.8?
                    search tech nobody on there has an S60 that weighs less than a 9", even with a iron center section the 9"is right around 200lbs. The S60 come in at 225 or more every time. The nice stuff like MWC of M9 can be made lighter than a 10 bolt. Car craft did a test of a 12 bolt, S60, and a 9" and they were all withing 6rwhp of one another with the 12 bolt being best and the 9" losing the most power. I would hardly call that much to argue about.
                      Correct a 9" in gonna weigh less then a 60. My car my rear end =D
                        I could care less what you put under your car, just have heard this debate recently and wanted to make sure good information was being passed along. Either rear will take the abuse end of story.
                          if youre worried about that axle, IMO you should be putting a cage in it to stiffen the chasis as well. FWIW Im twisting my quarter panels up even with subframe connectors and my 10 bolt is still alive and well.
                            Its okay Joel you are getting rid of your car for something euro! YOU'RE OPINION IS USELESS! [x]goes in corner and cries at the lost of a F-Body[x]
                              wow what is your budget gonna be for this? The suspension alone is gonna be outrageous
