Charlyne 95 Z28 M6
  • Well I ordered some stuff. Got something in mind. Will have to wait for pictures.
    Originally posted by Yoshi94
    • Well hung over so no work on the Camaro but I did at least get the Cruze washed and a coat of wax on.
      • Nice!
        • I decided to get something done on the Camaro. So I cleaned the valve covers and laid down a coat of primer. My color scheme is going to be black and lime green. Lime green valve covers and intake manifold. Plus badges and letters changed to lime green.
          • UPDATE:
            • New valve seals installed in Driver Side head.
            • Stainless Steel Manley valves installed
            • Driver Side head installed
            • ARP Head bolts
            Yes I did a better job at cleaning the surfaces, got a wire wheel and a pneumatic drill.
            Now I just need to get the passenger head off. I unbolted the power steering pump. Now the bolt in the PS/AC bracket that is hiding behind the PS pump is that the only bolt I have to remove to get the passenger side head off?
            427616_3296909098094_1128857949_3252403_1961352132_n.jpg417760_3296912858188_1128857949_3252404_1253425153_n.jpg424912_3297745038992_1128857949_3252982_152369175_n.jpg
            I wanted to do a 226/234 Cam swap while the engine was apart but I don't have the funds for it. So I just reinstalled stock springs and such and are putting her back together so I can at least drive her this year. Since we are all gonna die in December anyways right?
            • Hm interesting.
              Got the passenger head off. The number 2 cylinder has no heat on the spark plug, the exhaust valve looks different then all the others, the combustion chamber looks different. I put a caliper on the spring on the number 2 and 4 cylinder exhaust springs and the number 2 cylinder spring seems smaller, could be my measuring, its hard to get an accurate measure on them. So any ideas? I had no codes of a misfire.
              Bad valve? Or springs? Or what?
              418417_3303653866709_595232361_n.jpg429573_3303653386697_1128857949_3255173_1213164221_n.jpg422744_3303652906685_1128857949_3255172_1174222366_n.jpg
              • Wow - that spark plug looks like it has never even been fired...
                • I know an all plugs were changed at the same time. I am lost what is happening. If you look at the pictures from yesterday. All combustion chambers on the driver side head look like number 2 on the passenger side. Then 4 6 8 look different.
                  • Im guessing the pics got lost durring the server move?
                    • Ah forgot I have to update the configuration - I moved the attachments to a different location. Give me a few minutes.
                      • Should be working now - thanks for pointing that out, Spencer, I was just about ready to call it a night, would've sucked to have forgotten about that
                        • Almost buttoned up.
                          Some pics.
                          Last pic proves that there is room under a LT1 hood.
                          421590_3325497332782_1128857949_3264972_306613686_n.jpg421727_3325500212854_1128857949_3264976_1194528487_n.jpg423749_3325502932922_1128857949_3264979_614088505_n.jpg
                          • Car is back together and running.
                            Next step is to install the LCA relocation brackets, LCAs, and panhard bar.
                            • Currently starting the tune.
                              • Keep up the great work!
