Charlyne 95 Z28 M6
  • I beat them with a 4x4 and a mini 3lbs sledge.
    Originally posted by Yoshi94
    • Originally posted by Fox Slaughter View Post
      wtf and they didnt come off? lol holy shit son
      • Nope tried beating them from every direction I could. Tried a pry bar on the lip would bend my header first. Couldnt fit a putty knife under it.
        • Wow that for sure should not happen!
          • Put your purse down and try again
            • I'd walk away and try another day... When you hit the point where you're using a BFH and a 4x4 an inch from your valvetrain, you're not making good decisions
              • they should not be that tight, I do have a good set of LT1 valve cover PM me if your interested.
                • Its more than likely a cork gasket that was installed dry. Try and spray some penetrating oil around the lip.
                  • I will try the penetrating oil, I did step away I gave up for today on it.
                    • Pretty sure they have never been off.
                      • Thanks Larry for the valve covers. Its gonna be time to go Medieval on those valve covers.
                        Also Brian Red Alert rides awesome well until that utility pole got in the way, hey it was fun while the tow truck was on the way right? Hahaha
                          Haha yeah my dad called and told me he sold the valve covers... I wish my car was drivable!
                          • The rocker covers may have been sealed with RTV and you just may need to pry up a corner to break them free. They can be easilly straightened if you bend the lip.
                            • Well I decided to try again. Went out and grabbed the driver bank cover and pop, it comes off. No RTV just orange gaskets. Try the passenger side, since I have a new set of covers, it was stuck. Grab the hammer hit it about 5 times and grab it. Pop, comes off. The alternator is in the way of getting the cover off. So I grab my Craftsman Upright compressor I bought Aug 2010. I had the drain valve open to let the water out last time. Screw it out and it won't seal, air just leaks out. What the hell, so keep trying won't work. Okay I'll get a new one, go to Sears get a new one, $5.29. Put in it, before it even fully tightens it breaks off flush. WTF. So I called Sears they are like you are out of your 1 year warranty, it will cost like 30 dollars to diagnose the problem so like 40 to fix it. WTF! So now I'm gonna try to tap it out with a screw driver.
                              If its not one thing its another. Welcome to life. Damn it.
                              Haha I didn't know that was your dad? Good guy. Well fix that damn flex plate jeez!
                              • Well got the air compressor all straightened out. Just took a Ease out and my time.
                                Here are some progress pics. Some have been done before the season ended just never posted them.
                                332502_2644947759468_1128857949_2953733_761579230_o.jpg Here is the engine starting to be torn down.
                                290998_2661656297171_1128857949_2959381_1070621573_o.jpg Here is the first coat of primer going on old bashed valve cover that was stuck.
                                336108_2661654777133_1128857949_2959380_1290300470_o.jpg Fuel rails removed and polished by hand, might do them again with a drill.
                                338070_2645182085326_1128857949_2953826_1150999643_o.jpg QTP electric cut outs.
                                328836_2645178645240_1128857949_2953825_1923147955_o.jpg Hurst Billet Plus with Pistol grip, UMI Short Stick. The switch is for my cut outs and the grey wires hanging out are for my FAST Dual Wideband.
