Originally posted by Fox Slaughter
View Post
Charlyne 95 Z28 M6
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Yes let me crawl outside in the rain and lay under my car with my camera in the rain and then get soaked in the rain to take pictures that were taken in the rain.Originally posted by nascarnate326 View Postpics or it didnt happen
Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
Alright got my exhaust finished now, have to order cut outs. It hangs low haha. 3" with X pipe Pacesetter Ceramic Long Tubes, Cut outs, Delta Flow 40s at the Axle. Ill get some pics up in a few mins. Plus pictures of my Wideband o2s.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
Here is a few pictures. Video for some reason got quite when the exhaust came on haha. Cutouts are Closed in that video.
Lurker
- March 13th, 2010
- 3476
- TJ
I started to install my rear suspension parts but I could only get one side of the panhard bar off and couldnt even get the bolt out. I have a 1/2" impact gun that supposably does 625ft lbs and it wouldnt even move the driver side bolt, passenger I took off with just a socket wrench. I guess I'll have to start soaking them in PB Blaster.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
Super quiet with the cutouts closed. My neighbors lawn motor is louder then it at full throttle.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
the cam and cutouts must make a difference lol. My car wakes the neighbors up if i dont get a good run at the driveway late at nightOriginally posted by my95z28 View PostJoels car with the exact same setup set off my car alarm repeatedly.
sawzall ftw. just make sure you replace with grade 8 bolts!-Joel
Lurker
- March 13th, 2010
- 3476
- TJ
I tried using a 3lb baby sledge didn't work haha.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
