My 94 used an old style, my 97 uses a new style. Your 96 should use the new style. Eric L
Nate's Z28 Project
Thanks. Do you know if the insides are the same? Did it have to do with the OBD II change over?Originally posted by prorac1 View PostMy 94 used an old style, my 97 uses a new style. Your 96 should use the new style. Eric L
Ill just order one of the new ones. Getting some new keys made tonight.1998 Chevrolet Camaro Z28 - 6 Speed
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- 2023 Malibu, 2022 Explorer
- Winston Salem, NC
Wow, not sure how I missed this thread, but nice ride Nate, Congrats!!
What's wrong with the key fob?? Is it just not working?? Have you tried holding the lock and unlock buttons at the same time while in/near the veh until you hear the locks cycle?? Sometimes when you replace the batteries it needs to be reset. It could be that it's not even programmed for the car, if so I have a write-up somewhere of how to reprogram a new fob to the car, I can dig it out and let you know that process.....Shit now that I think of it, I may have seen that posted on here somewhere once too.
Are you programming the key or the fob???West Michigan Pontiac Club
Just thought id let you know, if the factory alarm is armed (either by the fob, or the door lock button) the only way to disarm is by the key fob, or by putting the key in the ignition and turn it to ON. If you open the door with the key you have 10 seconds to disarm the alarm(with the key) before it goes off. Just FYI.
Whats the difference between the old and new style fobs?1999 Camaro - 6 liters of fury.....
Newer Keyfob:
Older keyfob:
those keyfobs are so hit/miss. The one on my 99 worked perfect, the one on my truck... well lets just say i dont even bother and skip right to the key.-Joel
