Nate's Z28 Project
  • lifters and pushrods you can get for about 40 bucks i think itd be a 40 bucks well spent honestly.
    00 Tahoe Z71........Stock
    • Ive heard of guys using ls7 lifters in LT1s, those are more like $140
      • yikes! i thought lt1 costs would be comparable to sbc for some parts?
        • Originally posted by TylerT/AZ28 View Post
          My lifters were $90 alone buddy!
          • They don't make LT1 lifters anymore. Its now LS7 lifters.
            Last edited by Fox Slaughter; April 14th, 2013, 02:54 PM. Reason: Spelt Now wrong.
            Originally posted by Yoshi94
            • LS7 lifters are the LT1 factory replacement lifters now. If you went into a dealer and asked for lifters for an LT1 that's what they'd give you. Summit had the best price on them when I bought mine a couple years ago.
              • Originally posted by birdie2000 View Post
                To slow Jim. 28 years haven't treated you so well. I guess for your birthday I will get you some tennis balls so you put them on your walker so it will slide
                • well then didnt know that but still sounds like it needs to be doe and is worth the money regardless.
                  • i believe you may have you change out your pushrods for shorter ones, if you go to the ls7 lifter. not sure on this..
                    • Originally posted by Dummybait View Post
                      I rember reading something like that somewhere too. Definitely measure.
                      • yeah according to some stuff on ls1 tech, the ls7 lifters are .050 taller seat comparied to LS1 stock lifters. not sure about an LT1 though...
                        http://ls1tech.com/forums/generation...s7-lifter.html
                        • So they replaced the LT1 lifter with a piece that doesnt work with the other hardware? That doesnt make any sense.
                          • well like on my car, i had ls7 lifters put in and they replaced the pushrods with shorter ones. I think as a rule of thumb, lifters and pushrods are normally replaced, because of how inexpensive they are, i think i paid like 130 for the lifters and 112 for pushrods.
                            • I should probably check pushrod wear on my rockers sometime -- when I did my cam I went with stock length hardened push rods even though I had LS7 lifters and my heads milled.
                              • Nate i may actually have a set of trickflow 7.150 rods i didnt use (stock is 7.2 i believe). If so you can have them.
                                Also nate i agree that changing measurements is kinda a bum thing of them to do but look at it this way, the additional lifter height could mean a more functional lifter if there is added seat travel.
