Nate's Z28 Project
  • I second what Joel said I was like WTF? Haha.
    What in the hell is that ugly thing on top of the driverside valve cover?
    Originally posted by Yoshi94
    • Originally posted by ryanwarby01 View Post
      Nice job! Your car reminds me of something that would have been sold as a Special Edition from a Dale Earnhardt Chevy dealership.
      The Intimidator SS is my dream car
      @ your "hehehehe" at the beginning of the video
      Too damn excited!
      Thats the Traction Control/ Throttle Control.
      • Thank god mine does not have that ugly thing on there!
        • This is the plug that started it all. Got lucky and started moving wires and noticed a change.
          With my new plate
          And the two codes that were on...any idea?
          Im guessing the first one is a map sensor issue but the second one I have no idea.
          • Weird I didnt have any codes after my cam swap. It does sound like your rocker adjustment is a bit off the way the idle sounds. I would start there.
            • http://www.camaroz28.com/forums/lt1-...e-high-460962/
              Boom you lazy bastard. Took 2 seconds to Google.
              • nice job, its not a big deal to ditch the traction control. got rid of mine years ago it helps clean up under the hood
                • Yes ditch that ugly thing, who uses TC anyways?
                  • Sounds really good Nate!! Looks good too! I really like the intake blacked out like that! That plate is nuts!!!
                    [MENTION=2913]FASHOOTER[/MENTION] Every time i see you post and look at your avatar it makes me want a 97 anniversary ss sooo bad!
                    • the map would probably be cleared up after rocker adjustment, sounds good so far! will likely sound like god speaking when you do you rocker adjustments
                      00 Tahoe Z71........Stock
                      • It was definatly good to hear that beast fire up, it was about damn time haha . Glad we figured out the problem.
                        • Sounds real healthy
                          • thanks guys!!!
                            • Originally posted by Fox Slaughter View Post
                              Sounds like that ICM code could have been from before you replaced the ICM plug from your dad's Suburban. It also sounds like this code is stored and has to be cleared out. Have you tried clearing the codes and seeing if it comes back?
                              • I cleared the code and the flashing light came back but no code. Now that its running I am going to disconnect the battery and wait a few min to see if that helps it. I'm a little puzzled why it doesn't start with out some throttle, valves again?
