Looks great so far!
Nate's Z28 Project
i agree that a full turn seems excessive. Mine bottomed out a little past 3/4. But every setup is different and should be adjusted subjectively.-Joel
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
well i think one of yours was a bit tight since i sent you a pic of that lobe worn out. lol.Originally posted by JoeliusZ28 View Posti agree that a full turn seems excessive. Mine bottomed out a little past 3/4. But every setup is different and should be adjusted subjectively.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
That wasnt from my engine and i thought that was a pic of the cam from your truck! Thats kinda crappy then :/Originally posted by TylerT/AZ28 View Postwell i think one of yours was a bit tight since i sent you a pic of that lobe worn out. lol.-Joel
Post Whore
- 3000
- Tyler Porter
- student
nope that was yours lol. i was staring at it at home and staring at it and i was like WOAH thats not right lol.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
It was from the 4-bolt LT1 i bought. It looked like someone ran really bad oil in it, spun a bearing, and kept driving it that way
Post Whore
- 3000
- Tyler Porter
- student
no biggy i ordered a different one, wont be switching to roller but still appreciate the thought.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Looking good sir.
So to recap its a freshen up with a Hotcam correct?
If so should be a fun street bruiser.
Oh what did you decide about the rockers?
I still would recommend engine running method.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Yes its a fresh rebuild 350 with full hotcam kit, full exhaust, and tune.Originally posted by Fox Slaughter View PostLooking good sir.
Currently rockers are half past and I will need to do the running method I think.1998 Chevrolet Camaro Z28 - 6 Speed
Lurker
- March 13th, 2010
- 3476
- TJ
Yeah like I said I tried doing it like 3 times with the engine off, then started it didn't like it so I did the running method. I think its the best.
Looks like ~330 to ~350 with a tune.
Sucks the rear ends in the Fbodies are crap, otherwise I would say get some gears in that puppy too.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Post Whore
- February 19th, 2010
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
So this thing gonna be at the MSU Car Show????
Its whatever youre comfortable with. Engine running method was completely effing useless for me. I had no feedback whatsoever to tell where i was unless the lifter was bottoming put or i wasnt even at zero lash. Im willing to bet it will start and run just fine exactly the way it is now. How much past a half turn did it take to bottom the lifter? If youre close to halfway between zero and bottomed, you should be fine but it depends on the lifter.Originally posted by Fox Slaughter View PostYeah like I said I tried doing it like 3 times with the engine off, then started it didn't like it so I did the running method. I think its the best.
Also, engine off method might be more effective after its been run once, so the lifters are fully primed with oil.Last edited by JoeliusZ28; March 22nd, 2013, 11:50 PM.-Joel
Theres a C4 with basically the exact setup I have that made 348. I dont know what the difference is- IRS vs Solid Axel but I expect to be pretty close to that. I wont have it dyno'd until it has a different exhaust.Originally posted by Fox Slaughter View PostLooks like ~330 to ~350 with a tune.
Possibly No one does this much work and just turns the key without something coming up. Lots of systems to get back to normal (brakes, power steering, clutch, coolant, etc) Also depends on a pigment change I am thinking about.Originally posted by alone_and_insane View Post
Hopefully soon. We dont have kids yet but I think of it like waiting 9 months to see what your unborn child looks like. lolOriginally posted by 01CAMAROSS View PostLooks great Nate. Can't wait to hear the video of it's first start up!
This is what I am thinking too.Originally posted by JoeliusZ28 View Post
Going to fire it up, get coolant in it, check for leaks, and see how bad the rockers need to be adjusted. Take it from there.
How much run time before the first oil change?1998 Chevrolet Camaro Z28 - 6 Speed
