Nate's Z28 Project
  • OK guys, do I need to run 4 02 sensors? Plan on replacing all of them as I want this motor to run 100%.
    Remember I have longtubes with ORY and no cats. I have bung's for 4 02's.
    Previously I had them "tuned" out(dont know if thats true or not) and I only used the front two.
    Doing things right this time.
    • The rear o2's are used to monitor catalytic efficiency. Using them in your case(no cats) would accomplish absolutely nothing.
      • Can't wait to see this car come back togather.
          This. Plug em and tune em out.
          • My rear's are tuned out functionality wise, but if i unplug them they throw a code, so i just leave them plugged in, i'd like to just get them completely tuned out so i can remove them with no CEL
            • Plug them and plug them good
              • So is anything done to the tune like I have been told?
                Easier and cheaper for me. 2 new 02 sensors sure as hell beats 4 new 02 sensors.
                • Thats probably a question for your tuner. obdII is foreign to me.
                  • Nate's Z28 Project
                    The only thing that would need to be done to the tune is to disable the P codes associated with non functional rear O2s so the SES light doesn't come on.
                    • Originally posted by Schuby87 View Post
                      Ok then I believe it's already set up that way since I don have any ses codes.
                      In other news I ordered my opti. Going to get plug wres today at lunch. Getting excited!!
                        When do u you plan to peiceing it back togather? let me know, i'll give you a hand!
                        • Going to slowly put it back together as parts come in or are ready. Motor will not go in the car until its warm.
                          need to send the PCM out and get it tuned before I get ahead of my self.
                          • Paint heads silver or leave them in blasted aluminum?
                            Opti came in, gaskets, came in, got alternator premiered, and took apart the coil bracket to get it cleaned up and painted.
                            • I would leave them bare aluminum, painting them would be too much work for little reward.
                              • they are really dull right now. Everything is going to be "pretty" and these heads just bare.
