Nate's Z28 Project
    Lookin good, you should paint that pcm too
    I was thinking that too. Going to wait until after I get it back from getting a tune.
    Originally posted by BP_Z28 View Post
    How much did it cost for the rebuild?
    Dont know. Going over final numbers next week. Probably close to a grand is what I will owe the engine shop. I wont say that I dont care what it costs, but Im more concerned with it being done right vs cost.
      As much as it's not friendly on the wallet, that's definitely the right mindset to have.
      • Lookin good Nate. yeah paint that pcm for sure. the TB looks bad ass
        • I say paint the alternator as well. With everything else painted up, and in such a high visibility area, it will look terrible otherwise. I painted mine silver to match my STB, CAI, and elbow, and I thought it turned out pretty good.
          Before:
          After:
          Do it, you'll be glad you did.
          Originally posted by JasonH
          • Well I was just curious because I would like my LS to be rebuilt before a H/C
            • Finally an update, hopefully they start to happen more often closer we get to spring.
              Motor is going to be ~850 ish without heads put on. Thats for the motor as it was when I brought it into them with cleaning, all new bearings/seals, head bolts, rings, caps, and something else that I forgot.
              I went over and got the last few boxes of parts that have not been cleaned/ updated yet.
              Also got the trans and bell housing cleaned up and painted.
              To repair my heater box...what do I use? Its fiberglass and my old headers burned a hole in it causing my lack of vacuum pressure. JB weld? Fiberglass repair kit?
              • Looking good!
                My heater box has a repair to it by the previous owner that looks to be fiberglass. Should be pretty easy while the engine's out. How big is the hole?
                • looks great Nate!
                  • Originally posted by birdie2000 View Post
                    Looking good!
                    4 inches long, maybe an inch wide.
                    I put hi temp silicon on it last August just to try and get some better heat since I was going to be driving the car in October. It worked but looks like hell. I have no plans of this motor coming back out under my ownership lol.
                    • I should have mentioned this earlier are you replacing the rod bolts? Thats the weak link of our bottom end, some ARPs would be some extra insurance. Not sure what their cost is.
                      • is that a chevy front bumper?
                        rod bolts would be a great idea while your in there. sounds like an overall decent price.
                        00 Tahoe Z71........Stock
                          I'd definitely do fiberglass then. Shouldn't take more than an hour or two to do it right assuming you're brand new to fiberglassing. Clean the surface where you're glassing, smooth out any rough edges on the crack/hole, use fairly coarse sandpaper to rough up the area you'll be glassing for adhesion, then just follow the instructions in the kit. Let it dry, sand to smooth it down, hit with some flat black paint, and you'll never know it was done.
                            That will require resizing the rods
                            2015 Silverado
                              I thought they were, Ill have to check.
                              Yes, thats a suburban front bumper.
                              Yes I am new to fiberglass. Will the patch be strong enough to standup to my stainless headers?
                              Going to check, I didnt really ask about them when we went over everything.
                              • fiberglass isnt all that hard just read the directions a few dozen times. see if you have any clearance to notch the heater box so you wont melt it against your headers again.
