I sandblasted my heads and then painted them with silver VHT. Turned out fantastic.
Nate's Z28 Project
I'd paint them silver too. I think the silver paint would help keep the heads looking mildly "clean" whereas the bare aluminum would absorb dirt into the finish much easier.- Brian Meissen
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
You should be picky. Its your car.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Picked up my motor today. Everything looks good. Going to paint a bracket or two but its Clean Clean Clean.
The left is the blue I got this morning compared to bare aluminum
Fel Pro gaskets on the entire motor, top to bottom everything.
Genuine GM Optispark
Lots of parts ready to go back on the car
Painted one of the heads with a little VHT silver paint. Couldnt find "wheel paint" color so I went with this flat.
Cleaning my headers and y pipe tomorrow.1998 Chevrolet Camaro Z28 - 6 Speed
Did you do the Impala gaskets to bump the compression?
EDIT: Everything looks great. The attention to detail will really pay off in the end.Last edited by ryanwarby01; March 8th, 2013, 08:48 PM.sigpic
Post Whore
- February 19th, 2010
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
You should add this:
Looks awesome nate, love the engine block in the back of the hhr
Got a lot of stuff done this weekend.
Heads painted, coil put back together, and started on cleaning bolts. Long and tedious hours, anyone thats every did this knows what I mean.
Lots of painted, cleaned, new, etc parts.
At this point all I am lacking is a tune.
Where my car is at, a slushy muddy, nasty mess of a driveway separates my car and my dads barn. Meaning its not going anywhere until it dries up. Hopefully in the next few weeks.
my spark plugs have a few thousand miles on them. They look kinda dirty and gross. TR55's.
What plugs should I run?1998 Chevrolet Camaro Z28 - 6 Speed
What are you using to clean the bolts, Nate? If your dad has a drill press, get a wire wheel attachment that can be put in the drill press and it'll make cleaning all your bolts up a snap. That's what we did with my bolts when I was doing my build.- Brian Meissen
