Nate's Z28 Project
  • 15 minutes or so or a couple heat cycles. You just want to get everything lubricated and get the assembly grease out.
    • Mad tuner emailed me, my PCM will not be here today
      • Which O2 sensors are the front and which are the rears? We are trying to determine if the oval shape connectors are the front or the square shape connectors. Anybody know?
        • Maybe google the part numbers?
            Cant you just look at which connectors are where on your harness?
              this...
              btw i would run it for about 2-3 heat cycles before u change the oil. and then after 100 miles.. then 500 miles then every 3k
              • Originally posted by kammi10 View Post
                this...
                agreed.
                  The stock OBDII LT1 system is goofy. I believe it has 3 O2 sensors. I know the rear O2 are tuned out...but which ones are which.
                  I have a square plug on the drivers side, and a plug....flat O2 sensor on the passenger side as well as the square plug but I dont have an extension. Still dont know if we have it hooked up correct.
                  • Interior back together finally
                    ITS IN!!!
                    Getting very fed up with the traction control.....
                    Motors in just need to do a few more things:
                    put coolant in
                    put power steering fluid in
                    replace broken vacuum line
                    replace water temp sensor
                    put pcm in
                    put wheels back on
                    turn key.
                    Big thanks to Scott and Ben for helping me. Mad tuner gave me a refund for my PCM being late, it will show up Monday.
                    • Anyone know what this is?
                      • Weight reduction.
                        • unimportant
                          00 Tahoe Z71........Stock
                          • I was gonna guess that bracket that goes on the front driver's side of the intake near the TB, but I can see you already have that in, not to mention that one's too big.
                            The worst feeling in the world is when you get everything back together, and still have a couple of nuts and bolts sitting around...
                            Originally posted by JasonH
                            • Cruise control bracket? Just a wild guess... That doesnt look familiar. And you wouldnt believe how many random nuts and bolts i have leftover after suspension. I look at it and i dont believe it could have possibly been on the car. someones trolling me planting them in my parts pile.
                              • We did a fairly decent job with marking things but this one I just dont know. At this point Ill put it in the box with the other "Z28 parts that are no longer Z28 parts"
                                Going to get the interior cleaned up and put my rear seats back in.
                                Joel, do you know of a how to to disconnect the traction control system?
