Nate's Z28 Project
    I cleared the code and the flashing light came back but no code. Now that its running I am going to disconnect the battery and wait a few min to see if that helps it. I'm a little puzzled why it doesn't start with out some throttle, valves again?
    They would need to be binding quite a bit to cause that... But its possible. If you think it is, you may want to back your adjustment an 1/8th of a turn or so off every rocker just to be on the safe side... Would suck to wipe something out this early in the game
    • I'm curious to see what it will run down the 1/4
      • Originally posted by BP_Z28 View Post
        Me too. Wish I had a chance to run it stock to see what the improvement is.
        Amazing what a mood Change a running lt1 can make lol.
        • IDK what track is closer to you. But if you are in Lapeer, hit me up..track followed by a gun range session (since the lapeer pit is 1mile away form the track )
          • I think it would be fun to come over there and get in a few runs, do some shooting and go to dinner.
            Cant wait to go to Onedega once it opens up. That's not even 30 min from me.
            • Did you say the SES light was flashing?
              Cause a flashing SES light means misfire.
              Originally posted by Yoshi94
              • I believe the valves are good now, brakes are good (air in rear lines), and HVAC started working as well.
                Bad news is that the 02 plug vibrated its self out, should have used lock tight. Ill get another one tomorrow.
                Currently the brake light is on but it starts perfect, idles well, and drives decent. Has more cam surge than I expected for being a smaller cam.
                • Check brake fluid.
                  • Is it tuned yet? 95% of "cam surge" is in the tune.
                      This. Or a small vacuum leak.
                      • Yes, it was tuned by Ion.
                        I have to believe the tune is pretty much perfect because of the cams popularity but who knows.
                        • heres a crappy video from last night, hope to make a good one today with sunshine
                          • It sounds great! What exhaust do you have? I have been thinking about toning mine down a bit.
                            2002 Z28 Camaro A4
                            • Longtubes, ORY, no cats, Hooker, Magnaflow tips.
                              • Does sound good! I have the hooker Aerochamber and love it
