  • Should I tell you 13.6v is okay but I would watch it, it should be more around 13.9 to 14.2v.
    Originally posted by Yoshi94
    • Joel- It could still use some work the screws on the carpet look tacky.
      TJ- I read somewhere that fords usually run 14.0-14.3. Don't know how true it is
      Also that's with just throwing the battery on there after a little charge. Idk how great this battery is either just something a buddy had laying around.
      2002 Z28 Camaro A4
      • Like I said I'd watch it.
        • Haven't driven the car since I put the new battery in (rain all week)
          I'm planning on going to the MSU car show tomorrow so that will be the real test.
          I'm still waiting on a reply on the pair of 10 spokes. The guy said he has a busy work schedule and needed to find some boxes to ship them in. I mentioned going to a local discount or belle tire to get some boxes... I sent him another pm today.
          2002 Z28 Camaro A4
          • Went to the MSU carshow today. I was more curious what I got db wise more than going for the loudest car. Pulled 107db I think at 30 feet... I think I placed 4th or 5th out of ~25 cars.
            A open down pipe civic that sounded like firecrackers took first. Then I believe a gto and a huyabusa were after them.
            I developed a noise in my rearend. At first it was only in reverse now it's doing it around turns and some bumps. Only notice it at a real slow speed. It's like something is binding. Almost a grinding/popping noise. Not consistent. I looked under my car today and my drivers rear brake line to the caliper is leaking. I'm going to go check that out here in a few.
            Battery/charging system worked great all day.
            Any suggestion on what I should set my shift points to be?
            2002 Z28 Camaro A4
            • Just to be clear, our stock housings take a H4 bulb, correct? @Fox Slaughter have you used those cut off point cap thingys? I'm thinking of getting another set of hids and those caps so I don't have to hear you whine...
              Driving to work this morning in it with just the brights that weren't aimed for shit sucked...
              Cleared the front emblem, finally. Going to throw that on.
              2002 Z28 Camaro A4
              • The bottom caliper pin seems like its stuck doesn't it? The boot is collapsed. The top isn't like that nor is the other side.
                2002 Z28 Camaro A4
                • Hey hey Mr Whiney I don't care what you do. You live out in the sticks. I have not used the caps. I have never had HIDs.
                  • One of the ballasts on the hids is bad/the problem. Swapped lights from side to side. Triple checked my wiring. Three some stock lights back in for the meantime.
                    The guy FINALLY was able to ship the pair of 10 spokes so hopefully ill get them later this week. I'm going to have to bust ass on them to have them ready for the m&g. I still need a set of 315s if anyone has some PLEASE let me know. Hopefully this weekend I can install/weld my SFC's.
                    2002 Z28 Camaro A4
                    • 10 spokes are in Allen park. Should have them Monday
                      edit: I mean today, I went to a tigers game yesterday and thought it was Saturday lol
                      2002 Z28 Camaro A4
                      • Awesome! Look forward to seeing the "new look"
                        • It's clear no one follows this anymore
                          got the wheels, they will be dropped off to weldcraft in the am.
                          2002 Z28 Camaro A4
                            Do I not count?
                              Do I not count?
                              Thanks but you probably just felt bad lol
                              2002 Z28 Camaro A4
                              • Michael for whatever its worth I check in whenever something is posted. Dont worry people are following. Keep it up and keep posting the progress!
