  • Bad advice bad boy!
    Originally posted by Yoshi94
    • Got the SFC's in today.
      Picked up a new longer belt today. Going to throw that on. Then see if it will fix the charging issue.
      Also bought a relay for the SS spoiler / abs issue.
      2002 Z28 Camaro A4
      1993 Z28 Camaro M6- SOLD
      1999 Z28 Camaro M6- SOLD
      2008 Ford Fusion SE - DD
      • I love founders. I'm awaiting for them to drop their torque arm. I would like to see it.
        • So, I was investigating my charging issue. Tried different belts, didn't change anything.
          My little wire that plugs into the connector for the alternator is only pushing out 8.9 volts. Any idea why? I checked to see if it was rubbing anywhere and it wasn't. Ideas?
          edit: checked my friends 96 1500 and he had 11 volts.
          2002 Z28 Camaro A4
            What color is the wire?
            • Originally posted by hoogiesngrinderz View Post
              Red
              Should I try grounding the alternator?
              http://ls1tech.com/forums/lt1-lt4-mo...battery-2.html
              2002 Z28 Camaro A4
                Red
                sound plausible? I powdercoated my accessory bracket.
                2002 Z28 Camaro A4
                • Sounds plausible to me. Actually, I'm gonna have to check that on mine now too, lol. I painted my alternator case and am running a relocation bracket.
                  • Sounds very plausible. Sounds like if you powdercoat the accessory bracket that you have to file down the mounting points because it gets the ground through the engine ground points.
                    • Sounds plausible.
                      Okay I just wanted to be like the above 3 posts haha.
                      • -Joel
                        • fail... Now in resorting to the battery. It must have gone to crap over the winter.
                          2002 Z28 Camaro A4
                            YELLOW TOP OPTIMA!!!! I even checked mine is made in Mexico(so the mith they went to shit once being made there is false) and has outlasted 5 cars and i've killed it dead several times and ive let it sit in the camaro thru 3 winters! I also did a load test on it today and it passed with 100%!! Hands down the best battery on the market that is reasonably priced!!!
                            • I meant to say, one of my HID's stopped working
                              2002 Z28 Camaro A4
                              • Scrolling through some old photos.
                                Before:
                                After:
                                2002 Z28 Camaro A4
