Martian knows what hes talking about for sure. I'm starting to like the smaller cams. More torque down low to help the car accelerate early in the run.
- Greenville, MI
- Die Maker
I'm intrigued. +6 isn't what I expectedOriginally posted by Formula Z View PostJust one he specd for my setup.
223/231 .598 .617 112 +6
I think thats right
Thats for a stock 5.3 w stock heads, 76mm, ls6 intake, 4L80e w 3400 stall
Grammar Nazi
- January 10th, 2006
- 6647
- Jonny
- under par
- Huron Speed
Good deal! Should have went through me and I could have saved you some money a we talked about!Originally posted by Formula Z View PostJust ordered a custom grind boost cam from martin @ tick performance. This guy knows his stuff. Ordered a few other things over the weekend. Its time to start getting this project moving. Gonna be a long winter but for some reason I feel like im gonna be stressing getting stuff done before spring lolsigpic
Grammar Nazi
- 6647
- Jonny
- under par
- Huron Speed
Not exactly but I will be going through you on it. One of the last things im gonna worry about though.Originally posted by Superman09 View PostHave you decided on a turbo yet?sigpic
- - 5.3/4L80e/T7875 - -
- Huron Speed Turbo Kit -
1998 Formula
The +6 is advance ground into the cam. It moves the intake centerline.
I would spend the money on the 75mm turbine. Its just a better turbo all around for pretty much any V8 application. Your going to make more power with it and not lose any spool time over the 68mm IMO.
Grammar Nazi
- 6647
- Jonny
- under par
- Huron Speed
If you ever want to make power down the road, more than 600 rwhp, the 7875 is definitely wise to purchase now. Will save you money and time having to swap later on. The TC78 will work great now up to about 600 rwhp, however the 7875 will do the same and do it at less boost as well along with giving you more room to grow!sigpic
