Made up my mind, I'm done playing around with the 305. The truck deserves better. For now im going to dump some lucas in and let it eat, but long term its going to get a crate 350 and fitech injection.
K10 Project
TSTONE likes this.-Joel
- 1 like
JoeliusZ28 , I expect to see many progress updates from your current upgrade.
Added pictures-Joel
It's the performer EPS manifold.
http://www.jegs.com/i/Edelbrock/350/27013/10002/-1
I made my selection based on it making the best torque numbers, and also the fact it was available in black powdercoat. I want this install to look as factory as possible and the main reason for changing the intake out is so i could keep the original intake/carb/and emissions stuff all together as a unit so it can be bolted right back on if someone wants to do that. I labeled everything I disconnected. The new intake cleans everything up and any added power is a bonus.
No plans on doing headers, although I considered doing both that and a small cam. At the end of the day, it would still be slow so i decided it wasnt worth the time/effort. Just want this truck to run and drive without drama.-Joel
Also should mention im changing out valve seals and power steering pump while im in this deep (power steering pump squeals). Its probably going to be a week or two before i even get to start putting it back together.-Joel
One more thing. I seem to be having a problem with rust mixing into the coolant. Anything i can do to stop this besides flushing it again? I think i ran water too long a couple years back during the 30 or so flushes it took to clean the crap out.-Joel
You might need to run something like this through to clean it all out: https://prestone.com/products?detail=AS105Y
And okay, I'll have to see where the EPS fits in compared to the Performer and Performer RPM. My engine is blue, so the black powdercoat might look a little "off" on mine. But that's a little ways off anyway.Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
Its available in the standard bare aluminum as well, cheaper that way even! And yeah, thats the chemical flush i originally used on the first flush. I'll probably need to do it again. Just need to make sure i dont clog my newly rebuilt radiator up with rust crap.Originally posted by MP81 View PostYou might need to run something like this through to clean it all out: https://prestone.com/products?detail=AS105Y
And okay, I'll have to see where the EPS fits in compared to the Performer and Performer RPM. My engine is blue, so the black powdercoat might look a little "off" on mine. But that's a little ways off anyway.-Joel
I actually don't think they offer the EPS in a spread-bore. I'm pretty sure the Air Gap won't fit under the stock hood, with the air-induction air cleaner (though I may go the custom route there and make my own. I really don't need the provisions for the heat riser or anything. But having the PCV and EVAP connections at the air cleaner still are probably a good idea. Either way, I'm limited in height of what I can use. The Performer RPM costs about $70 more than the regular Performer.Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
ah i thought you were thinking about doing an EFI. Yeah, you'd want a spread bore manifold.-Joel
