K10 Project
  • Little soon for that, isnt it?
    • thanks for the share, hope all turns out well
        The car cover? Yes. The battery just took a shit so i just threw the cover on it for now its not done for the year though. (My black car gets dusty in about 2.3 seconds...)
        Thanks! Guess i havent updated in a while, but yes it did. I replaced the egr valve so i could get it back on the road without reconfiging the distributor and carb. It did the trick, ran great on the road but still had a shaky idle which wound up being a vacuum leak. Its running and driving great now, but i still need to go through and replace all the vacuum lines.
        I also have a recurve kit for the distributor now, so if i want to delete egr and retune everything i can.
          I also have a recurve kit for the distributor now, so if i want to delete egr, put a giant cam in it and retune everything i can.
          Sounds like a great plan. Especially the giant cam.
          • Yes, ron jeremy cam and 150 shot of nitrous for the *****in 305 this winter
            • For America.
              • Any ideas? The noise i thought i had fixed came back. Afraid it might be trans again...
                This is highway speed, 70mph varying throttle
                • Just sounds like something rattling to me.
                  • It sounds rotational to me. I was hoping it was a rattle. (still am). i pulled the inspection cover off today to make sure it wasnt that, but no luck. same noise. i think its an input or output bearing biting the dust
                    • Some of you probably already saw i put a dual exhaust kit on. Ordered it from LMC and used aerochambers instead of the supplied mufflers. I'm still working on perfecting the hanger and fit situation but for what i have invested im pretty happy with it so far. I want to try to add an h-pipe and i am probably going to cut/relocate the tailpipes and add tips. Right now i think they are too close to the tire and directly in the way of where a mud flap would be. But anyway, the little 305 is definitely happier now that it can breathe.
                      I'm still trying to figure out the rattling in the transmission. I have it narrowed down to either a throwout bearing rattle (not the bearing itself but a worn clutch fork), or an input bearing. Hoping its the first.
                      • Lookin' and sounding great! Plan on using this in the winter, or will it be tucked away from the salt?
                        • definitely not driving it in the salt. It is insured year round, so if the conditions were perfect i might take it out but the collector policy states im not to endanger the vehicle by driving it in snow.
                          • endanger the vehicle... thats funny.
                            • Almost like it is a person!
                              In that case, keep it far, far away from the salt - and Michigan winter drivers.
                              • Lol it sounds ridiculous but it saves me from having to switch between storage and regular insurance at a rate that assumes im not really driving it for 4 months out of the year.
                                Also i got the rest of the exhaust hangers finished tonight and its lined up about as perfect as i can get it. I think for the rear hangers i want something more than a single sheet metal screw but other than that everything is solidly in place. I took it for a test drive and its a noticeable improvement. More power all around and it wants to rev more/higher than before. Happy with the sound too but i think it'll be even better if i fab up an h-pipe later.
                                .... Flash photography makes that undercarriage look really bad. POR15 and painting everything is going to be one of my winter projects.
