Surely your car could take a 100-150 shot
- the trans might not last forever but I do have window switch that help it out
Spray that *****
Progress - I think I have everything where I want it. I need to run the main feed for the N20 then start wiring.2000 Formula
fixed slow junk
damn it's been a month since an update....
11" Monster race disc is in
PST 3.5 aluminum shaft with billet yokes is in - strange cm shaft didn't ever seem to be balanced right
Nitrous is just about wired up - just need to run a couple more wires and figure out the window switch
Motive 4.10's are in a box - want to break the clutch in before putting new gears in it. I don't know how much the clutch is going to chatter :x
Pro 5.0 is installed - and it shifts nice
Exhaust - I put it back together with a crappy merge, might come back off. If so I'll install my stepped edlebrock headers. I'd like duals but there isn't room with the tunnel mount torque arm.2000 Formula
fixed slow junk
4" is a no go - 3.5 will fit. I'd have to get a different torque arm mount from MWC to fit 4" and that's another $200. Anything has to be better than 2 3" pipes coming to more of a "t" than a "y"Originally posted by c0ncEpT View Post3-4" Flowmaster merge with a 4" cutout would work great with you set up. It can be made to fit around a tunnel mount torque arm also!2000 Formula
fixed slow junk
Agreed. Would clean up the exhaust note a lot also.Originally posted by Nocooler View Post4" is a no go - 3.5 will fit. I'd have to get a different torque arm mount from MWC to fit 4" and that's another $200. Anything has to be better than 2 3" pipes coming to more of a "t" than a "y"
I've seen 4" through the UMI tunnel mount and didn't think they got much tighter than that!
I made the exact same thing on my car. Except I have a bullet dumped under my back seat.Originally posted by DETROITMUSCLE View Postits a tight fit, it will all be changed again here soon though.
Knowing how tight of a fit that UMI piece is and how much of a pain it was to get my merge to fit, Id hate to see the MWC!2015 Silverado
Son of a *itch - the local place that was filling bottles doesn't anymore.......that means I need to drive to greenville or midland, both an hour away.
Should have just put a turbo on it.....2000 Formula
fixed slow junk
Does the "Y" merge improve the tone of the exhaust compared to it being a "T" ?
For example this being the "T"
And this being the "Y"
