Spray that *****
  • #31
    Originally posted by Formula Z View Post
    seriously sucks about the clutch jeremy. larry does need to up his shot... i have a 125 shot sitting in the garage but dont think it will be installed this season. i wanna see what it will do with the new setup on DRs and a fresh stall.
    Unfortunately clutches are a wearing item. It's all good.
    2000 Formula
    fixed slow junk
    • #32
      Originally posted by OIF1VET View Post
      Larry is perfectly happy at a 100. Not upping the shot until I can afford a stand alone fuel system.
      Be prepared next time you go to the motorplex - they made me go back through tech after making a 11.4/11.3 pass. Make sure your helmet is Snell 2005 or 2010, belts are still valid, you have a fire jacket.
      2000 Formula
      fixed slow junk
      • #33
        i dont think i have any of this. oh boy
        • #34
          you need a roll bar too.....
          2000 Formula
          fixed slow junk
          • #35
            i thought you guys were sliding by staying above 11? guess my dragstrip days are numbered
            • #36
              I saw your car last year. Bad ass. Can't wait to see it run on spray
              • #37
                11.50 is the cutoff for the bar and safety gear....
                2000 Formula
                fixed slow junk
                • #38
                  even a 15.00 requires a fire jacket if your car didnt come with boost or n20 from the factory
                  • #39
                    They didn't give me any problems with boost. But I drove in with street tires
                    • #40
                      I heard you can always make like one run, then they check your car and go you don't have this you have to leave.
                      Originally posted by Yoshi94
                      • #41
                        Nothing to report as of yet - still planning on being down for awhile until I'm healed up enough to work on it.
                        I did order some more fuel jets so I can fine tune the kit. I have .026-.042 jets for fuel now - that should provide enough range to get the 75/100/150 shots dialed in good
                        2000 Formula
                        fixed slow junk
                        • #42
                          This ***** should move out on a 150 hit. Should have no problem trapping 130-135 when you get it all sorted out.
                          • #43
                            If you want I can borrow the kit for a bit and make sure everything is in working order, even get you close on the jet sizes
                            • #44
                              I sure you would!
                              2000 Formula
                              fixed slow junk
                              • #45
                                Originally posted by Nocooler View Post
                                I sure you would!
                                yep right up until something broke on my car
