Spray that *****
    Stock K-member? I got one to come out the other week by disconnecting the mounts and lifting the engine. Had a tubular K-member tho.
    Stock Kmember and quicktime bellhousing - it's tight with the engine up as high as it'll go I need another 1"
    2000 Formula
    fixed slow junk
    • Originally posted by Nocooler View Post
      This is exactly what I had to do, drop the k and lower it on a jack because I couldn't get to the top bolts because the Quicktime isn't tapered like the stock housing.
      Originally posted by Yoshi94
      • Pan is out - it'd be back together, but I ran out of brake cleaner
        O-ring wasn't pinched - the pan had a some graphite in it from changing the head gaskets, but other than that it looked good.
        2000 Formula
        fixed slow junk
        • Getting work done - pan is on, k-member back in place, engine mounts bolted down
          I don't know why everyone on tech complains about how much of a ***** the poly mounts are - everything went right back together.
          2000 Formula
          fixed slow junk
          • It lives -just need to put the exhaust back on it
            2000 Formula
            fixed slow junk
              Sweeeeet!
              • Exhaust is done - man I forgot how tight the tunnel is with a 3.5" driveshaft
                2000 Formula
                fixed slow junk
                • Learned a few things out last time.
                  I'm lean - no fuel ring - nada, plug is 100% clean - and the timing mark is really close to the bend.
                  I made a pass with the bottle off and forgot to shut the kit off - and it picked up 3 mph on the motor spraying fuel only......so I'm going to have to add some fuel n/a and see if can get some more out of it.
                  So I have some tweaking to do - and it should pick up.
                  2000 Formula
                  fixed slow junk
                  • good find! Let me know the next time you go back to the track. I got my 3rd member back in, just need to install the axles, etc
                    • Looks like no tnt until July 4
                      2000 Formula
                      fixed slow junk
                      • nice discovery psyched to see how much it picks up next outing.
                        • Well I also found out why it was so damn lean on the bottle - apparently the timing wasn't dropping when it hit the airmass tables that I pulled it from.
                          So I've been spraying on 30* of timing all along
                          Plugs all looked good - no signs of detonation, and they all had straps
                          I've made some changes to the tune and I need to see if the timing will stay where I set it or if I've got another modifier somewhere adding timing.
                          2000 Formula
                          fixed slow junk
                          • dang I didn't know you were trying to push this motor so hard I bet it sure felt like a hell of a pass. good thing you caught it early enough on and didn't hurt anything.
                            • Wasn't the plan Jeff.
                              I just kept forgetting to log it.
                              It's only had 5 bottles through it @ 30* - doh.
                              2000 Formula
                              fixed slow junk
