Spray that *****
  • All the parts are here - now I just need decent weather to get the car home to tear into it.
    2000 Formula
    fixed slow junk
    • x2
      I jacked mine up yesterday to start my valve spring swap but that's as far as I got b/c it's too f'in cold in my barn with no insulation and a small heater
      • Do you have the valve spring tool?
        2000 Formula
        fixed slow junk
        • Originally posted by Nocooler View Post
          yeah, I have the crane cams one that does 2 springs at once. Glad I bought it for my first cam swap several years ago b/c I seem to use it almost every year lol
          • I also have the crane/Vinci. I need to pick up the ls3 and a ls7 version. Or I may get the Lsm tool
            • Cool - I was going to say - break mine in for me
              2000 Formula
              fixed slow junk
              • Drove it home today. Hooked the battery back up and she fired right up.
                It was definately pissy with the cold plugs in it
                2000 Formula
                fixed slow junk
                • Exhaust is off and the drivers side header is ready to pull out, I was just to tired to crawl back under the car.
                  2000 Formula
                  fixed slow junk
                  • Headers are out and the belts are off - I decided to call it quits after 45 minutes.
                    2000 Formula
                    fixed slow junk
                    • Alternator is out - A/C compressor is lowered and out of the way.
                      With any luck tomorrow I might be able to get the mounts out and the oil pan baffle installed
                      2000 Formula
                      fixed slow junk
                        • Mounts are done, EGR/Air tube removed from the headers & welded up. Headers are wrapped.
                          Oil pan wouldn't come out by jacking the engine - looks like I'll have to lower the k-member and jack the engine.
                          2000 Formula
                          fixed slow junk
                            Sorry didn't read all 20 pages lol, why you pulling the pan? Jim said it was because it went on the bumper at stanton. Hope to see ya around this year at stanton, ill be out there soon hopefully to claim my slowest lt1 in michigan title
                            • Originally posted by dawdaw View Post
                              Not on the bumper....maybe this year.
                              Oil pressure drops hard at launch and doesn't recover as fast as I'd like.
                              I have a http://www.improvedracing.com/oil-pa...ffle-p-30.html baffle for it - so that should take care of the issue.
                              2000 Formula
                              fixed slow junk
                              • Stock K-member? I got one to come out the other week by disconnecting the mounts and lifting the engine. Had a tubular K-member tho.
