Originally posted by hoogiesngrinderz
View Post
Project: 1967 Firebird 326 Rebuild
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Under the valve covers and the valley looks like it was a barbeque for like 20 years.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
Its like on a bbq right? Carbon from the burned up food gives flavor right? So it was just flavoring the engine. How many miles were on it?Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Wow that's a lot of sludge! Good work guys!- Brian Meissen
Lurker
- March 13th, 2010
- 3476
- TJ
I'm going to say not taken care or rolled over. I've torn down engines, my LT1 with 105k, with over 200k miles and didn't have anywhere near that much sledge.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Ran fine other than a little oil leak and the timing being a bit off... but we just felt it was time for a rebuild. My Dad is hoping to take it out to PA and back on a tour this June.Originally posted by nascarnate326 View PostThing is, for as bad as it looks....it still ran right?
The main drive-ability issue IMO was the suspension, which will be completely rebuilt with new bushings, springs, ball joints, etc.2000 Trans Am l 1967 Firebird
Wow that is a lot of sludge, moving right a long with this... Making me want to go pull my engine out now..sigpic
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
State Motors on Gratiot is where we had B's engine done. Ph 586-294-5660 owners name is Rich. Cam did not look worn in picture, just discolored. I think older oil sledged up when you started and ran short trips not getting engine to operating temp.sigpic
Another good guy/shop to call is Bob at Autobohn. He is in Lowell and all he does is old Pontiacs. 616-897-7679. I have used him a lot and is great.sigpic
- Greenville, MI
- Die Maker
I never knew there was a builder right there. I'm about 6 miles from his place!Originally posted by ryanwarby01 View PostAnother good guy/shop to call is Bob at Autobohn. He is in Lowell and all he does is old Pontiacs. 616-897-7679. I have used him a lot and is great.
