They will work, but OEM LT1 pistons use metric rings. Measure the ring land gaps.
1996 Camaro Z28 LT1 Project
- Greenville, MI
- Die Maker
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
- Greenville, MI
- Die Maker
I know he's running aftermarket pistons, just need to verify ring thicknessesOriginally posted by birdie2000 View PostHis bottom end was rebuilt and I'm nearly positive those are the pistons that were used.
H597ACP is the LT1 version (metric ring) of their stock replacement pistons.
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
I know the 2256 is the number of the piston used and it is forged. Beyond that, I'm not sure if there is anything LT1-specific needed although I can't say I've heard of an LT1-specific part # for them. I think they did have a slight change in design over the years and/or change of branding but IIRC the measurements are the same.
- Greenville, MI
- Die Maker
Most of these seem to be multi branded - Sealed Power, Speed Pro, TRW, Federal Mogul, etc. If I remember right, the two sets I have used had the part number stamp etched into the top of the piston. Probably the easiest way to check
LT1 was just the change over to metric 2mm, 1.5mm, 4mm ring land pistons, they could still use the earlier 5/64", 5/64", 3/16" pistons. Just wanted to make sure, I thought I had a set of brand new rings on the shelf that would work...they are standard bore rings unfortunately.
- February 19th, 2010
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
I'm going to stick with forged pistons...no sense in having one stock piston and the rest forged.
- Greenville, MI
- Die Maker
I only see the L2256F20 sold in set of 8. Summit has WL2256F20 sold individually, same specs on their site though. $43.99 each.
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
.Originally posted by hoogiesngrinderz View PostI only see the L2256F20 sold in set of 8. Summit has WL2256F20 sold individually, same specs on their site though. $43.99 each.
Originally posted by birdie2000 View PostFWIW, here's the replacement piston: http://www.summitracing.com/parts/sl...6f20/overview/
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
I guess that's the one, then! Now I just gotta make sure I get the correct rings.
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Did a little shopping today. Ordered the second piston, rings, rod bearings, and head gaskets.
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
[MENTION=1504]mcalus[/MENTION] and [MENTION=1151]nascarnate326[/MENTION] , didn't you guys have HIDs on your cars? what was your setup?
Yep. Ddm tuning 4500k. I put them in the stock housing which is frowned upon since it blinds oncoming traffic but I never got flashed so I'm guessing I had them pointed to the ground enough.
I didn't drive at night very often but when I did it was so much better than stock lights.2002 Z28 Camaro A4
