1996 Camaro Z28 LT1 Project
  • Got some better pictures of the carnage:
    Thankfully, the bore looks just fine (the piston, not so much)
    Better picture of the debris I plucked out of the head:
    Originally posted by JasonH
    • Weird - so that little chunk of metal is what did all that damage?
      • Well I imagine there were more chunks of metal, but the rest of them got blown through.
        • Whats your plan at this point? Have the motor fully rebuilt?
          • Cut the filter apart. If it looks clean I'd pop 1 piston in it and repair the head.
              What Mike said is my plan at the moment, but cutting the filter apart to see what it caught would be a good idea. I haven't seen any metal shavings at all in the oil or anywhere else, though.
                Agreed. Maybe also check the main bearings while you're at it, just to make sure there's no major wear ... though if you're not seeing shavings then you might be safe.
                Once it's back up and running, I'd buy a bunch of store-brand oil from O'Reilly or Autozone or where ever and dump that in. Let it heat cycle and then change the oil. Check for shavings, bearing dust, etc. Run it for 100 miles or so and change the oil again, repeat process, etc.
                  Yup, also what I was planning on doing haha
                  • Dumb question: how do you cut a filter apart without getting shavings from cutting the filter, into the filter? Or are the chucks obvious as opposed to the metal dust from cutting?
                    • punch a hole in it and use tin snips
                        Good question, I hadn't thought of that. Thanks for the answer, Joe.
                        • no prob, unfortunately I have had to do this on more than one occasion.
                          • Ahh yes, I was thinking pneumatic tools
                            • So I'm gonna be doing some more work tomorrow, and I have a couple questions for those of you who have pulled these engines multiple times:
                              1. Is it easier to pull the engine with the harness still on it, or to leave the entire harness in the car?
                              2. Where do you remove the brake lines? Last time we disconnected them at the ABS module and left that much of the lines connected to the k-member, which ended up being a big PITA
                              • I always just leave the harness in the car and strap it out of the way with like a bungee cord. Fairly certain I always disconnected the lines at the module before I got rid of ABS
                                Sent from my SAMSUNG-SGH-I537 using Tapatalk
                                2015 Silverado
