I bought my old 02 Z28 back.
    Do it up! It?s not like we hangout lol. I can send you the guys info if you want it.
    If you don't mind, send it over!
      Another small issue I have is I think the exhaust might be vibrating against the body somewhere. When under heavy acceleration it sounds like a grumbling noise coming from the rear somewhere. It?s either the duals rubbing or I have a bad trans mount. I need to get it on the hoist at work and see if I see anything.
      If its under heavy acceleration its probably related to the motor mounts flexing, chances are you'll find your contact mark near the front of the car.
      • Looks sweet!
        mcalus likes this.
        • Sent from my iPhone using Tapatalk
          Tang likes this.
          2002 Z28 Camaro A4
          • Looking good!
            • Awesome looking car. SOM for life!
              Sent from my Pixel 2 XL using Tapatalk
              mcalus likes this.
              2002 Pontiac Trans Am WS6 (Tang)
              Mods: Fikse Profil 10, GTP stage 2 heads, TR227 cam, Kooks 1 3/4 headers with ORY, Corsa catback, SLP Blackwing lid, SLP smooth bellows, Thunder Racing CNC ported stock throttle body, BG Ram Air, GM 4.10's in 10 bolt, B&M Ripper shifter, ATI 25% UD Super Damper, BMR Suspension, Tuned by Dr. Phil
              • I haven?t done too much.
                Swapped out both tensioner pulleys and both idler pulleys, installed new belts. My ?chirp? at idle went away.
                Looking to pick up some speed engineering longtubes, motor mounts, plugs and wires for a winter project. I also have been wanting to do some 3.73s.
                2002 Z28 Camaro A4
                • Almost perfect... just needs an SS hood with a satin black stinger...
                  mcalus likes this.
                  • if you would like another tail light panel to make a Berger panel I have one in my garage I want to get rid of. and the price is right, free.
                    mcalus likes this.
                    When in doubt, Whip it out !
                    • Originally posted by farmington View Post
                      I can never find people like you when I need parts for my Firebird lol
                      • Almost as bad as when you have a decent part and can?t give it away?
                          If I?m ever out your way I?ll take you up on that offer thank you!
                          2002 Z28 Camaro A4
                          • Car is looking sweet! Really like what you've done to it in such a short time. Those duals are gonna scream with long tubes, especially if you cut the cats. My GMMG sounds awesome at idle, but definetely screams at WOT, but the cam definetely doesn't quiet mine down either...hehe
                            I have been kicking around the idea of having a body guy do the tinted tailights like you did, but taping off the reverse section to leave it clear and bright. Other option i thought of was having them tint them by lightly tinting the clearcoat with me NBM body color as well. But it has been low on the list and haven't seen pics of the body color tinted tailights. Being a body guy, do you think the idea of just lightly tinting clearcoat with NBM would work to lightly tint the tails?
                            mcalus likes this.
                            Jason Ebig
                            Federal Firearms/Class 3 Dealer
                            $20 Firearm Transfers
                            • Originally posted by ZYA_LTR
                              Thank you! I really hope the longtubes wake the true duals up. I?ll definitely be deleting the cats. The YouTube videos hopefully don?t do the car justice because it sounds really quiet even with longtubes. I guess we will see.
                              Typically I add a little single stage into the clear when tinting the tails. Since you can?t add basecoat into the clear you?d have to make some clear base (basically clear basecoat) and add a little nbm into it then clear over that. I?d assume it would work I just don?t know how well it would cover over the yellow or red. Worst case scenario you sand it off. Also, painter not body guy, those guys are hacks lol.
                              I have been tossing around the idea of widening another set of 10 spokes. I?ll probably only go 10.5? wide this time around instead of 11? since I had to beat more of my inner fender wells than I wanted on the ppm car. Also I?d rather not run spacers unless I have to. Maybe 1/4 spacers and some longer studs will do the trick.
                              MP81 likes this.
                              2002 Z28 Camaro A4
                              • is it just me, or do those tires look super knobby haha
                                Originally posted by JasonH
