I bought my old 02 Z28 back.
  • Dex got a bad rap because it attacked intake gaskets when it first came out but that was over 20 years ago. I haven't heard of any issues with it since then
    MP81 and mcalus like this.
    When in doubt, Whip it out !
    • Okay I?ll just keep the orange coolant then.
      Got some motor mounts and O2 extensions for Christmas
      2002 Z28 Camaro A4
      1993 Z28 Camaro M6- SOLD
      1999 Z28 Camaro M6- SOLD
      2008 Ford Fusion SE - DD
      • Always nice to get parts for Christmas!
        Why is the extension needed? Headers?
        • Originally posted by DynoDave
          Yes sir!
          2002 Z28 Camaro A4
          • Day 2 into this thing and I?m ready to burn the ***** to the ground lol. Any suggestions on getting this lower trans line off? Using a line wrench and it?s starting to strip. Thought about cutting it at the straight part and using a rubber line and a clamp since I?ll have to re route somethings anyways for the aftermarket trans cooler.
            I never have good luck with vice grips and there isn?t much room for them anyways.
            Suggestions?
            2002 Z28 Camaro A4
            • Can you edit posts from Tapatalk?
              I did a little researching and I don?t think it would be much different if I cut it and just added some rubber line and a fitting later. Basically the same thing that they give you in aftermarket trans coolers. Also I can replace both lines when I install the stall.
              Another question, what should I do for tuning? I was going to do a mail order until I work out any bugs but is my trans going to be all over the place if I tune it with a 4000 stall and not have said stall installed? Basically once the cam is installed I?ll be driving it to my co workers to put the stall in (~25 miles one way). Not sure at what point I should have the mail order done.
              2002 Z28 Camaro A4
              • There isn?t a lot that is changed for a converter in the tune, mainly raising rpm limiter so you don?t hit it on shifts.
                mcalus likes this.
                • Made some parts look a little fresher today.
                  alone_and_insane likes this.
                  2002 Z28 Camaro A4
                  • That trans line is a PITA, it's the same way in the LT1 cars. Maybe take a cheap wrench, heat it up, and bend it to get a better angle on it. Crescent wrench really won't work, end wrench is all you can do. It's probably stripping because you really aren't on there perfectly.
                    Originally posted by JasonH
                    • Originally posted by alone_and_insane
                      Yeah at this point I?m just going to cut the line so I can carry on. I?ll either use a rubber hose until I can replace it when I do my stall or I?ll use a compression fitting or something.
                      2002 Z28 Camaro A4
                      • Once you cut it, then you can get a 6 point socket on it. If still loose, try it's metric / English counterpart.
                        • Cleaned up the water pump. Added a 160 degree stat.
                          2002 Z28 Camaro A4
                          • WOW - those all look a whole lot better!
                            mcalus likes this.
                            • Thats awesome
                              mcalus likes this.
                              • Made some really good progress lastnight.
                                Removed the coils, and brackets, exhaust manifolds, power steering pump, radiator.
                                Someone broke the drivers rear manifold bolt so it?s a good thing the heads are coming off.
                                I was going to remove the intake but I don?t have a fuel line disconnect tool so I?ll grab one from work.
                                The cam kit came in the mail yesterday
                                2002 Z28 Camaro A4
