huron speed tractor kits?
I'm 99% sure all turbonetics are rebuildable.Originally posted by Formula Z View PostI knew it wasnt cheap. Just trying to be at the point where it might come out by the end of next summer. Is that $700 turbo rebuildable?
Sent from my SPH-D710 using Tapatalk 22000 Formula
fixed slow junk
Grammar Nazi
- January 10th, 2006
- 6647
- Jonny
- under par
- Huron Speed
You can have Turbonetics rebuild it if you need.
Those prices are CHEAP! You should see what some other turbos cost!
I wouldn't put anything less expensive than a Turbonetics on the car. If so you will really be sacrificing power as well as quality of the turbo.sigpic
its true.. list price onthe bullseye i have is like 13xxOriginally posted by Superman09 View PostYou can have Turbonetics rebuild it if you need.
- Lowell, MI
- Meat Processor
wow..Originally posted by kammi10 View Postits true.. list price onthe bullseye i have is like 13xxLast edited by kammi10; November 13th, 2012, 02:49 AM.
Considering putting my stock 3.23s back in also. So my 3.73s may be up for grabs. What difference would this make going turbo/80e besides the obvious rpm/mpg
Sent from my SPH-D710 using Tapatalk 2Last edited by Formula Z; November 24th, 2012, 06:13 PM.sigpic
- - 5.3/4L80e/T7875 - -
- Huron Speed Turbo Kit -
1998 Formula
nice! gonna have to pull it and take it back into work and have it swapped out. or i may just have to hold out for a bit as something else is in the works. car might not make it out next year so i have a little bit of time to make it right. still not going with a cage so my options may be a little slim. thx mike!sigpic
1998 Formula
What's wrong with a roll bar? Should have sat in my car with it......or better yet Jim's he has swing outs. Unless your carting midgets around the back seat is worthless.2000 Formula
fixed slow junk
Re: hp/tq/ and 1/4 with a 76mm/78mm turbo
What has to ne done to get a double roller timing chain behind front cover? Looking at a chain pump combo from slp on summitracing
Sent from my SPH-D710 using Tapatalk 2sigpic
1998 Formula
After doing some reading I went with the LS2 timing set due to function and price. PM me if you're interested in details. I'm using the Melling hi pressure pump.2015 Silverado
