Which Cam?
  • Screwed in its a predetermined length, each half or full turn (cant remember which) is .050
      full turn
      - 2012 Mustang GT 5.0 - M6 / Brembo Package / 3.73 / Bama Tune / Catless X / Corsa Xtreme /
      • I did not get the "hi-tech" one.
        I wish I would have, mine just has two jam nuts.
        1996 Base Model
        +2 cylinder mod
        • Dont think ive ever seen one like that.
          I would guess get it where you want it and measure it with a micrometer or something.
          • calipers should work fine but a micrometer is more accurate
            • I'll have my dad bring a micrometer home from work.
              1996 Base Model
              +2 cylinder mod
              • The cam should be here today or monday according to LE.
                He said there is not a tracking number which is weird.
                Also, I used to order number on Comp's site and nothing comes up.
                1996 Base Model
                +2 cylinder mod
                • I thought LE used Bullet for his cams, did he switch to Comp?
                  • That's what he said.
                    1996 Base Model
                    +2 cylinder mod
                    • Originally posted by jderry View Post
                      you will need a 7" mic. it sound like you push rod tool was sesighned for 1 time use. comp used to sell cheep ones that you would lock down with the jam nuts and then send into who ever was building your push-rods(trend performance is down your way. set it then take it to them and walk out right then and there with your push-rods.
                      Trend Performance, Inc.
                      23444 Schoenherr
                      Warren, MI 48089
                      Toll Free: 1.800.326.8368
                      Tel: 586.447.0400
                      Fax: 586.447.0440
                      Email: info@trendperform.com
                      http://www.trendperform.com/index.php?go=home
                      these guys are almost as good as using manton push rods. which iv used in top fuelers
                      the tracking portion is weird unless they used usps. as for comp cam order/ grind number they are all le's desighned and orders so it may not show up.
                      dont quote me on this but i dont think loyd ever used bullit.
                      i know he uses comp cams now. bullit is where i buy my seriouse cams the have a better knowladge base when it come to custom ground cams.
                      • Maybe, or I can just Mic them and get as close as possible in pre made sizes.
                        It was shipped "UPS G".
                        1996 Base Model
                        +2 cylinder mod
                          huh again loyde has stumped me. i have only had delayd shippment from him. never had a cam not show up. as far as push-rods go that what i was getting at. you can set the tool, drive to warren and walk out with your push rods then. or just mic them and wait for summit or whom ever to send them. either way your getting what you need.
                          • Originally posted by sniperperformance View Post
                            Alright, I think I'll just order them online, a few things I need to my build are back ordered anyways.
                            1996 Base Model
                            +2 cylinder mod
                            • I cant find the oil drive saver at all.
                              What should I do.
                              Use the one I have?
                              Get new GM one?
                              Spend ~$150 on the billet aluminum one?
                              1996 Base Model
                              +2 cylinder mod
                              • I would definitely recommend a new one. It's not worth risking a weak link over $ 100. If you have an issue it could ruin all your hard work. A new GM unit is about $75 and the billet housing from Herron is $ 125. For me the $50 extra is cheap insurance not to have to worry about a problem in the future, like you could have with the GM plastic housing.
