Almost positive it isnt that high. Maybe it is, its been a long time since Ive been to the track, and I really dont beat on my car too much. Mines been put away since October? I will have to data log next time I go to the track, I never have before.
Which Cam?
Originally posted by c0ncEpT View PostYou need to put a tire on that car. I went 1.6x with STOCK suspension and 320-ish RWHP-Joel
Originally posted by c0ncEpT View PostI would be pretty excited if it made 325+ to be honest. There is no way in hell it will make anything over 339 either IMO.
I know autos typically do more with less but usually thats because of the launch. You trapped dead nuts even with a 370rwhp 6 speed at the track, and from a roll. The way i see it... When two similar cars (weight, friction, etc) pull the exact same from point x to point y, the same power is going to the wheels. If not, either physics were broken that day or i no longer have any faith in dynos
But that said, id have to hand it to you on a small weight advantage.-Joel
Originally posted by sman View PostAutos are not as efficient. To the wheels, hes probably making less than you. Manual cars always dyno higher.-Joel
I would say crank hp could be the same but rwhp will read lower on the dyno through an auto. There is no way that car will dyno 370 on the same dyno you were on. Remember gearing and weight play a factor in your calculations as well.Doing less with more
Originally posted by c0ncEpT View PostIf it makes 370 I think it would be a new record for a stock internal LS1. Most I've ever seen is in the 340's through an auto-Joel
Originally posted by JoeliusZ28 View PostSay what you will. I blow the ka-f***ing doors off bolt on LS1s all the time, especially autos.Doing less with more
Originally posted by DETROITMUSCLE View PostThere are less informed people in every car following that may not always be the best representation of what a car can do, just sayin.-Joel
I don't disagree but remember mike's car wouldn't even make the top 50 Bolton car list. Just food for thought they are out there.Doing less with more
Originally posted by DETROITMUSCLE View PostI don't disagree but remember mike's car wouldn't even make the top 50 Bolton car list. Just food for thought they are out there.
All im saying is his engine is either making some really power or he has some really trick weight redux. If he was making the same power with approximately the same weight as me he would have trapped less, not the same.
He isnt making 370, but i really really dont think 325 is any closer...
Sorry to hijack your thread JerryLast edited by JoeliusZ28; January 17th, 2012, 07:15 PM.-Joel
Originally posted by JoeliusZ28 View PostThat list has no restraint on weight, so I've also seen stock LS1 turds that can't even turn over a set of street tires. They weren't all created equal it seems.
But not a problem.sigpic
1996 Base Model
+2 cylinder mod
