You can say the same thing about a TR224. But the fact is its old technology. All the new lobes out today are far superior to the old XER lobes IMO.
Then again going with anything short of a custom cam spec'd specifically for your combination is a waste. Again IMO
im right there with yah. never understood why someone would lay good money down for a shelf cam when they could save $100-$150 more and buy something that ment for there specific apllication.
Also, do you guys think I should get all MSD stuff: cap, rotor, wires, and coil?
I don't want to have stuff with unknown miles fail and down my car.
personally with optis ive ran threw a few, different brands and such. best luck with the lifetime warranty one from autozone. plus when it takes a crap ive gotten it down to a couple hour science. not saying they are bad but my first msd last a 1/4 to the main road threw my subdivision before it took a dump. wasnt impressed.
Was it the whole Opti or just cap and rotor?
I have a GMP opti, which has less then 10,000 miles on it, but my cap and rotor are unknown
Opti: I have a CMS opti that kicks ass. Its half covered in oil and still works perfect with quite a few 6000 rpm shifts. 90 bucks for the entire assembly. DO make sure and get some new seals though, I didnt and regret it. No matter what you do its still an opti and your limited to design. I would stay away from MSD.
Wires: I have your basic cheap set from autozone, works fine. Who ever says you HAVE to have expensive wires is on crack. My car pulls plenty hard for what it is, I think you would do just fine with cheap wires. They are probably made in the same factory anyways. I put TR55, and switched my delco wires to the autozone and noticed no difference. In my head, its better because its fresh and new.
Coil: IMO only replace this if yours isnt working.
Waterpump: IMO only replace this if yours isnt working. I do keep a spare in the basement for when not if mine goes out.
All my stuff has 170k on it and still works fine.
Weep hole: run a clear tube. Use clear that way it will be more obvious if there is something coming out it(should be green). It may turn slightly yellow but I would still go with clear.
