Mine had free play too. Good move on getting the billet piece - it's way overboard for builds like ours, but the insurance it gives is priceless. Is that the stock gear or the hardened one from Jegs?
It's a stock one I believe, it's a Delco.
I rather spend the $125 for the billet one then have the "what if".
Mine looked fine, but no point in letting an engine fail over the money.
Also, what should I put on the head bolts? The old ones had what looked like a sort of pipe sealant, while my new ARPs came with their torque product.
always use thread sealer. the head bolts thread into open coolant passages. just alittle on the begine of the head bolt will do just fine. i use arp brand.
Alright, I'll get some of that. As far as setting the oil pick up height, I measured pan depth and got 7.75 inches. I measured the height of the pick up while it was still mounted and got 7.5. Do these numbers sound good? How should I do the new one?
Also, I think I will be getting this one brazed, should I bother?
that sound good for the pickup, i always tig weld the pickup to the pump. i have a tig welder so i use it. brazing will be fine, just go all the way around it to ensure that it will hold and a perfect seal between the pickup and the pump. sound like you have a good grasp on things here your doing well.
So does anyone know the best way to use the LT4 ED water pump gear?
Should I press the old one off and reuse the bearing, or get a new shaft and put the new gear onto it?
im sorry john i didnt see your question. get new shaft and new gear. sorry man
