Which Cam?
  • #76
    Originally posted by jderry View Post
    After talking with my dad a bit about it, I think I may go with the 228/236. Also I am going to try to get my heads milled, and a possible valve job done.
    if you get head work done i would opt for a 5 angle valve job. it will help alittle. key word alittle.
    • #77
      I sold my truck today, so it's looking like I have some more money to play with.
      Planning on the 228/238 .576/.571 110 LSA CAM
      Comp 26918 springs
      Comp 795 retainers
      Comp 611 locks
      Comp 1618 rockers
      Comp 3307 timing chain
      GM performance .028" head gaskets
      I already have the
      LS7 lifters
      GM Performance studs
      Comp Viton valve seals
      and more
      1996 Base Model
      +2 cylinder mod
      • #78
        I think you will be very happy with that cam.
        • #79
          I'm sure I will be too. Should be a pretty fun setup.
          1996 Base Model
          +2 cylinder mod
          • #80
            I agree, sounds like a great cam for what you want to do with the car.
            Originally posted by sniperperformance View Post
            i only go to LE for cams
            I've seen you say this on here before. I'm curious, why do you like LE's cams better than AI's, especially when using AI's heads?
            • #81
              dont forget pushrods. I also did LT4 knock module which I dont think its manditory but I read alot about doing it.
              • #82
                I will be getting them once I measure for legnth.
                I got the LT4 KM when I did my LT's and ORY
                1996 Base Model
                +2 cylinder mod
                • #83
                  Looks like your going in the right direction to building a strong running car. Remember don't cut any corners! People that spend not only the money but time to do all the small things are the ones that are rewarded in the end.
                  • #84
                    Amen. Will you be doing the white oil pump spring? I don't think my bearings would be alive today if i didnt do that.
                    • #85
                      YES YES YES.
                      I already have it on my desk
                      1996 Base Model
                      +2 cylinder mod
                      • #86
                        What would my compression ratio be if I milled the heads .02 and used a .028 gasket over the .05?
                        1996 Base Model
                        +2 cylinder mod
                        • #87
                          Thats what my setup is, i calculated 11.4:1. Your engine will actually be very similar to mine, just a Very slightly larger cam.
                          • #88
                            http://www.summitracing.com/expertad...on-Calculator/
                            did you use that?
                            1996 Base Model
                            +2 cylinder mod
                            • #89
                              I honestly dont remember how i calculated it, that was 3-4 years ago now
                              • #90
                                It's saying it's be like 11.7, either way that should be fine with 93..
                                Just ordered my rockers, gaskets, and timing chain.
                                They're saying .006 is equal to 1 cc
                                so .020/.006=3.3333
                                58-3.3333=54.667
                                http://www.dmperf.com/compression.htm
                                using that calculator, it says I'd come out to 11.85:1
                                1996 Base Model
                                +2 cylinder mod
