Project: PBR-Built Z/28
    spray some carb cleaner around your brake booster, perhaps its leaking?
    Yup, that's where the Miata is leaking from
    • The more i think about it that makes a lot of sense. Wish i was at home to check that quick.
      Although i dont think that explains the deadspace in the pedal... Maybe i have a couple of issues going on,
      • Ls or
        ctsv swap time
        • Anothet, cheaper option might be to also look at the cobalt brembos.
          • Again, hardware is 100% not the problem here. I know its hard to believe, but my stock brakes actually work great. Using the right hardware goes a long way. Ive got 4 seasons on these hawk HPS/raybestos combo and it still all looks like it was installed a week ago.
            At this point I'm pretty certain this is a problem with either the vacuum line, vacuum check valve, brake booster, or POSSIBLY the master cylinder.
              i just replaced all my brake lines, switched to a new master cylinder, and re did a few other things on it. my brakes feel 10x better than the stock master.
              • Did you use an aftermarket one or just a stock replacement?
                • its a strange master cylinder
                  • time for hydroboost....
                    • Maybe i'll convert to manual drum brakes!
                        I still have like 40-50% life left (if not more) on my HPS pads that I installed in November 2010...I just replaced the [Raybestos Advanced Tech] rotors last year...those pads last FOREVER, produce hardly any dust, and man do they bite when they warm up.
                        • Manual brakes wouldn't be a bad idea. If CP cars can do it, so can you.
                          • perfect time to redo the front system with ctsv or 5th gen setup
                            • -Joel
                              • Hey Joel I think they want you to do CTSv brakes...
