View Post
Project: PBR-Built Z/28
The issue is that i flipped one of the brackets to relocate the lines higher. In the stock position they would have been blatantly in the way of the exhaust. The stock torque arm seems to be somewhat formed in towards the driveshaft, it is not a straight shot from the pig to the transmission whereas the UMI is perfectly straight.Last edited by JoeliusZ28; October 19th, 2012, 06:31 AM.-Joel
I never realized you still had stock fuel injectors. When I went with the CC503 cam everyone was telling me to upgrade to 30# injectors right off the bat.- Brian Meissen
Yessir, my fuel system is completely stock. Maybe its been leaning out up top, maybe not. who knows.ive never had a *working* wideband on it, but it obviously hasnt beem significant enough to hurt anything in the last 4 years and 12k miles.Originally posted by meissen View PostI never realized you still had stock fuel injectors. When I went with the CC503 cam everyone was telling me to upgrade to 30# injectors right off the bat.-Joel
True - the upgraded fuel injectors might help it out a bit more.- Brian Meissen
I more or less decided that i would not tolerate the car being in its current mechanical state any longer. It was either sell it or stick some money into it, i chose the latter.Originally posted by bri2203 View PostAwesome, Brent must have given you a few branches from his tree!
I agree you have your work cut out for ya for a winter project. Let me know if you need a hand.-Joel
Brian, where did you buy your injectors? Or where is a good place to buy injectors?-Joel
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
james point was the thirdgen keepers arent like that at all. each line is flush to the trans mount, and its completely out of the way and tons more room that the setup on a 4th gen apparantlyOriginally posted by JoeliusZ28 View PostThe issue is that i flipped one of the brackets to relocate the lines higher. In the stock position they would have been blatantly in the way of the exhaust. The stock torque arm seems to be somewhat formed in towards the driveshaft, it is not a straight shot from the pig to the transmission whereas the UMI is perfectly straight.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
Hmm, really. Do you have one i could look at?Originally posted by TylerT/AZ28 View Postjames point was the thirdgen keepers arent like that at all. each line is flush to the trans mount, and its completely out of the way and tons more room that the setup on a 4th gen apparantly
Edit: actually really wont matter, i need to get them away from the exhaust too.Last edited by JoeliusZ28; October 19th, 2012, 12:28 PM.-Joel
Post Whore
- 3000
- Tyler Porter
- student
not anymore, ill search on tgo to dig something up just cause91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
I'll see if my old man still has some friends from work that aren't retired. Sure do miss getting "sample" lifters and injectors from Delphi.
I got my set of refurbished Ford SVO 30# on ebay for some ridiculously low price (like ~60 bucks low) and seem to be the best bang for the buck
Edit:
I think it was Fuel Injection Connection on ebay that I got mine from:
http://www.ebay.com/itm/30LB-REBUILT...647a1e&vxp=mtr
Here's another set to keep an eye on (I thought green tops were 36# but could be 8 injectors originally for the XR4Ti turbo 4 cylinder)
http://www.ebay.com/itm/30LB-REBUILT...647a1e&vxp=mtrLast edited by hoogiesngrinderz; October 19th, 2012, 05:54 PM.
Thanks Michael!! I'll look into that.
Out in the garage right now working on opening up the trap door. Also, here is a pic of the EFI Connections kit i bought from Ryan. Harness should be plug and play with exception of the transmission which will need to be re-pinned. Will be using a 2002 PCM.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
The 24x is a real slick setup!!
