Project: PBR-Built Z/28
  • Originally posted by OVRKILL View Post
    Cant speak to the injectors, but would like see an X-pipe and the choke-masters gone.
    Lol. I built it this way intentionally because I wanted the sound. I figured dual 3" would be "OVRKILL" for my power level anyway, it certainly doesnt have any trouble breathing
    • I would say from a search on tech that you should be fine (granted its ls based, but should still be close): http://ls1tech.com/forums/pcm-diagno...injectors.html
      open headers for the win
      and that is an h-pipe there smarty pants
      • Also curious about injectors... Since we relitavily have the same setup.
        2002 Z28 Camaro A4
        1993 Z28 Camaro M6- SOLD
        1999 Z28 Camaro M6- SOLD
        2008 Ford Fusion SE - DD
        • Originally posted by jetice View Post
          Do LS cars use the same capacity injectors? I can't even remember what LT1s have stock.
          Oh, and I definitely tried to start the car open headers today... freakin fuel pump wouldnt fire for me one last time! Boo!
          • Stock for 94+ lt1 is 24#-hr. And boo is right! I couldn't imagine how loud your car would be with open headers
            p.s. I thought they had 26's in them. You are right on the edge for a 24#
            • Hmm, ill have to check into that.
              Also, i will 100% for sure be doing SLP springs/shocks this winter as well as new founders LCAs and installing that torque arm. I will plan on a project beer & pizza day sometime this winter. I expect it to be a completely different car in the spring .
              • Mathematically you are at 100% on duty cycle, and quite possibly going lean at upper RPM. 30# injectors seem to be the normal for 450 bhp NA engines.
                • IIRC, LS1s have a higher base fuel pressure which usually gives an injector more flow.
                  • Originally posted by hoogiesngrinderz View Post
                    Thanks man, can i ask how you calculated that?
                      lol...whiskey factor. Well aware of the diff in a X and an H. Meant to say wanted to see an X..........and while you're at it. Ah hell never mind
                        Good to hear! glad you will stepping up!
                          good start....
                          http://www.gtsparkplugs.com/InjectorSizeCalc.html
                            • I thought the stock injectors were 28lb/hr
                                (Brake Horsepower X Brake Specific Fuel Consumption)/(Number of Injectors X Duty Cycle)
                                This is with the injectors flow rated at 43.5 psi. I like to see the duty cycle below .85. BSFC is typically between .45 and .50 for NA cars - .50 is normally used for the calculation
