Project: PBR-Built Z/28
  • Originally posted by OVRKILL View Post
    Fred...
    Those shocks almost gave me a heart attack trying to install the sway bar without touching ANYTHING!
    • Originally posted by Superman09 View Post
      Huron Speed is direct with Nasty Performance who can get about any fuel system component needed!
      Can you get the racetronix setup?
      bueller?
      • Put a solid 8+ hours of work in today with a buddy Jarrod and got quite a bit done! Started off trying to make a fuel line plan, then got ADD and moved to the suspension when we started running into the EVAP crap I didn't even realize was still on my car. Got the rear suspension mostly done... springs, shocks and relocation brackets. Thinking about ordering a sway bar now, kind of forgot about that. I am hoping the springs settle just a weeee bit because it sits maybe 1/2" lower than before. And just a heads up for anyone doing relocation brackets, apparently they require longer bolts. Going to have to hit the hardware store.
        Also, there was a change in plans today. I've been doing more homework on the SLP springs and decided I definitely want the front lower. So after trying to go conservative on this project, a set of BMR 1.25" springs are being shipped anyway! I think it is going to end up perfect stance with just a bit of rake.
        • the brackets didnt come with bolts?
            Iirc you can order them with or without hardware.
            Looks great Joel!
            2002 Z28 Camaro A4
            1993 Z28 Camaro M6- SOLD
            1999 Z28 Camaro M6- SOLD
            2008 Ford Fusion SE - DD
            • I bought them used from someone on this site. They did have the mounting bolt at least.
              • Joel, I can't tell from the pictures, but the bolt that goes where the LCA used to bolt in, and now hold the bracket, should have a sleeve to keep the welded on stock bracket from being crushed.
                • Good catch. Pretty important part.
                  • It does . I am quite pleased with the stellar fit of everything. Its all snug yet doesnt bind the slightest bit.
                    • Put an angle finder on those LCA's at ride height. A good start is 1-2 degrees downhill at ride height.
                        We'll have to see if the springs settle any but for now it looks good
                        • Looks golden like the shower!
                          • I would also like to add, I can't wait to see your car without the lift kit
                            • Go take it for a drive and it will settle real quick.
                                Sure, but sort of requires a working fuel pump, fuel lines, and a torque arm
