I am sending an email to the guy (former sponsor here) that made my lines for me, i will see what he says.
Project: PBR-Built Z/28
Hey Joel - are you going to need just a new engine harness or are you planning on repairing the harness you have?- Brian Meissen
After crawling all around the car last night I think the harness is fine. Just needs some reinsulation. The harness is eventually going to be replaced for 24x anyway, i just dont want to get into that project yet. My low oil sensor was the only connect that got signifcantly melted.-Joel
Dave at EAA engineering is sending me a complete replacement connector, which is what i asked for. Fingers crossed ill have it back on the road soon.-Joel
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Lowell, MI
- Meat Processor
https://www.holley.com/products/plum...ts/AT991966ERL
I prefer this style around vibration. Actually need the quick disconnect tool to remove, plus they have retainer clip just in case.
I wonder if i shouldnt switch to that style connector. I originally switched to threaded because i didnt even remotely trust the plastic quick connects the factory used, but a metal housing and clip changes things.-Joel
yikes!! I almost got those lines when i did my swap. I'm not positive but i think Huron Speed distributes them for EAA now.sigpic
Yes thats correct but I dont want to point the finger at EAA here. I installed the lines i may not have tightened them enough.Last edited by JoeliusZ28; June 3rd, 2015, 09:24 AM.-Joel
Agreed - I don't think it'd be appropriate to place blame, since nobody knows what happened.
That being said, you'd be totally justified in being a little leery and wanting to swap them out to something like Mike posted. At least, I know I'd be leaning that way after all this.
I would suggest using these as your fittings for those fuel lines.
http://aeromotiveinc.com/products-pa...orb-08-port-2/
http://aeromotiveinc.com/products-pa...ter-fitting-2/
No longer your average SS
nobody's placing the blame anywhere lol, but it's nice to know that if getting those lines it's not a bad idea to upgrade the fittings beforehand and then keep an eye on them.Originally posted by Atrus View PostAgreed - I don't think it'd be appropriate to place blame, since nobody knows what happened.
That being said, you'd be totally justified in being a little leery and wanting to swap them out to something like Mike posted. At least, I know I'd be leaning that way after all this.sigpic
Pretty sure he will give you whatever fittings you want. I asked for threaded when i bought them because the original plastic quick connects on my car scared me. Something like Michael posted is a lot more like what a quick connect should be.-Joel
Nowadays theres not a single thing wrong with quick connects. But there was a lot wrong with the factory 1995 quick connects... They were junk new let alone 15 years later.... Why i replaced them.-Joel
God I'm glad you're alright and the car didn't suffer more damage. Someone up there likes you.
This is exsactly why I have one of these mounted in my car...
I hope I never have to use it.sigpic
